Thread: Dry Aluminium Cutting Problem
It is.
I don't think you'll find many people on this forum use flood coolant. My setup is merely a pond pump in a bucket, connected with some 16mm hose to the Z-axis upon which I've clamped a coolant hose to the spindle. There's a picture in my build log.
You might find that mist coolant would be enough to reduce the heat build up since although it clearly wont conduct much heat away, the coefficient of friction between the cutter and the material is reduced so less heat is produced to start with. Did you use any lubricant at all when cutting the part pictured?
28-01-2013 #2
Aluminium is a bitch for clogging up tools. Plenty of cutting oil and/or coolant is the only way to reduce it.
Aluminium cutting
By Bush Flyer in forum Metalwork DiscussionReplies: 55Last Post: 13-05-2016, 09:57 AM -
Cutting Aluminium With A Cheapo 3020 CNC
By Pointy in forum Metalwork DiscussionReplies: 5Last Post: 05-05-2014, 09:59 AM -
aluminium profile for cutting bed of router
By steeplejack in forum Marketplace DiscussionReplies: 3Last Post: 19-10-2013, 10:52 PM -
RFQ: RFQ: Need some thin aluminium cutting
By stewpid22 in forum Projects, Jobs & RequestsReplies: 0Last Post: 21-09-2012, 01:11 PM -
WANTED: CNC Mill/Router for Cutting Aluminium
By kylelnsn in forum Items WantedReplies: 5Last Post: 09-08-2012, 09:54 PM
