Thread: Dry Aluminium Cutting Problem
29-01-2013 #9
I cut aluminium dry all the time with just blown air and the odd squirt of WD40 and it's not a problem for me. I have mist and flood but both are messy. Flood obviously sprays every where and mist can be fumey depending on whats used. I only use them when finish is important but mostly I cut with just blown air.
What grade aluminium are you using because looking at those pics and the way it's grabbed and furred up it looks very much like the soft shity 1020 stuff you find in thinner sheets.
The grade of aluminium makes a massive difference and this soft stuff is like milling cheese strings and will defiantly need coolant.!
What size cutter, feeds/speeds and DOC are you using.?
Aluminium cutting
By Bush Flyer in forum Metalwork DiscussionReplies: 55Last Post: 13-05-2016, 09:57 AM -
Cutting Aluminium With A Cheapo 3020 CNC
By Pointy in forum Metalwork DiscussionReplies: 5Last Post: 05-05-2014, 09:59 AM -
aluminium profile for cutting bed of router
By steeplejack in forum Marketplace DiscussionReplies: 3Last Post: 19-10-2013, 10:52 PM -
RFQ: RFQ: Need some thin aluminium cutting
By stewpid22 in forum Projects, Jobs & RequestsReplies: 0Last Post: 21-09-2012, 01:11 PM -
WANTED: CNC Mill/Router for Cutting Aluminium
By kylelnsn in forum Items WantedReplies: 5Last Post: 09-08-2012, 09:54 PM
