05-02-2013 #11
Assuming your z-axis can reach just below the top of the bed for surfacing it for doing flatsheets then that will be the lower limit of your z-axis travel. But for doing fourth axis work the lowest limit you need is the centre of the spindle, any material lower than that gets rotated upwards towards the cutting head.
So if you have the 4th-axis centred on the the z-axis limit of travel, you can cut 6 inch radius stock with 6 inches of z-axis travel. If you move the centre of the 4th axis up 2 inches this means you can only cut 4 inch radius stock with 6 inches of z-axis travel because the 2 inches you have below the centre will never be used for doing 4th axis work but your z-axis still needs to be travel that far to reach the bed when doing flat sheet work on the rest of the table.
Putting the centre at the same height as the bed results in the shortest required z-axis.
In reality you can position the 4th axis centre slightly lower than the top of the bed because your z axis will reach down that low for surfacing the bed and you never ever want to cut all the way through a piece of spinning wood that requires the support of two centres because it will fly off the machine at great speed doing a great deal of damage to any fleshy human type objects in it's path.
BUILD LOG: starting from scratch- router 1st project
By idefix in forum DIY Router Build LogsReplies: 24Last Post: 10-01-2014, 12:53 AM -
NEW MEMBER: Have Built 2 CNC machines 1 mill/drill conversion and 1 Router/plasma from scratch
By AGB in forum New Member IntroductionsReplies: 3Last Post: 06-02-2013, 03:16 AM -
Hypertherm Duramax Torches to upgrade Powermax 1000 & Powermax 1250
By Hypertherm John in forum Manufacturer NewsReplies: 0Last Post: 04-03-2011, 03:26 PM -
Building from Scratch or follow some plans?
By Monk in forum Gantry/Router Machines & BuildingReplies: 22Last Post: 12-08-2010, 10:27 PM -
Need helpwiring up from scratch
By GeorgeD in forum Machine DiscussionReplies: 40Last Post: 13-07-2010, 06:23 PM
