These were the photo's Dean sent to myself, which will serve me very well. I,m looking at doing spindles, table legs ect with the odd 3d items thrown in at some point. I,m keeping it as high as possible, as opposed to as low as possible. The higher you go the less z travel there is which will keep it stronger. What the photo's dont show is that Dean has an adjustable table, which i will have as well. When i,m doing 200mm deep material (engraving fire mantles), the z is going to travel 30-40mm, and the table will be removed. When i come to do thinner materials, i,ll fix the removable table, which will allow the z to travel, again, 30-40mm, which will keep the machine as strong as possible. Once i get a start made to it, i,ll be running things by Dean just to make sure that i,m heading down the correct road, as i only want to build one machine once. I look forward to seeing your progress D.C.
BUILD LOG: starting from scratch- router 1st project
By idefix in forum DIY Router Build LogsReplies: 24Last Post: 10-01-2014, 12:53 AM -
NEW MEMBER: Have Built 2 CNC machines 1 mill/drill conversion and 1 Router/plasma from scratch
By AGB in forum New Member IntroductionsReplies: 3Last Post: 06-02-2013, 03:16 AM -
Hypertherm Duramax Torches to upgrade Powermax 1000 & Powermax 1250
By Hypertherm John in forum Manufacturer NewsReplies: 0Last Post: 04-03-2011, 03:26 PM -
Building from Scratch or follow some plans?
By Monk in forum Gantry/Router Machines & BuildingReplies: 22Last Post: 12-08-2010, 10:27 PM -
Need helpwiring up from scratch
By GeorgeD in forum Machine DiscussionReplies: 40Last Post: 13-07-2010, 06:23 PM
