06-02-2013 #11
Like I did say several times these drawings where just for showing the principle and general layout. Alex has specific needs, which I knew ence how it's roughly drawn and he will design the specific heights etc around his needs.
Obviously if he or anyone else was just cutting 1" panels then the Gantry and so therefore the Z axis and it's overall extension would be less so yes in this case you would want the 4th axis lower but it's horse for course's and really that's a different machine a "Panel router".
To be honest if I wanted to turn legs etc then I'd use a lathe because building a 4th Axis that can spin fast enough for turning and still give high resolution for good 4th axis detail is very expensive, not hard just expensive. 4th Axis come into there own when you want to engrave or decorate, flute or barly twist etc and it's for this I'd use one and not for the actual turning.!!
BUILD LOG: starting from scratch- router 1st project
By idefix in forum DIY Router Build LogsReplies: 24Last Post: 10-01-2014, 12:53 AM -
NEW MEMBER: Have Built 2 CNC machines 1 mill/drill conversion and 1 Router/plasma from scratch
By AGB in forum New Member IntroductionsReplies: 3Last Post: 06-02-2013, 03:16 AM -
Hypertherm Duramax Torches to upgrade Powermax 1000 & Powermax 1250
By Hypertherm John in forum Manufacturer NewsReplies: 0Last Post: 04-03-2011, 03:26 PM -
Building from Scratch or follow some plans?
By Monk in forum Gantry/Router Machines & BuildingReplies: 22Last Post: 12-08-2010, 10:27 PM -
Need helpwiring up from scratch
By GeorgeD in forum Machine DiscussionReplies: 40Last Post: 13-07-2010, 06:23 PM
