04-02-2013 #9
I looked at buying a board with plug in driver boards but couldn't find one that worked above about 36v. You might find that that is not enough for your choice of motors. The motors I used would have operated at 36v BUT I would never have got the best out of them so opted to go with 3 separate drivers that could handle a much larger voltage.
You will get lots of help with control box set up from members on the forum so don't let your lack of knowledge (at the moment|) put you off. Quite a few of the build logs have most of what is needed covered so reading them will give you a good start for your own system.
BUILD LOG: starting from scratch- router 1st project
By idefix in forum DIY Router Build LogsReplies: 24Last Post: 10-01-2014, 12:53 AM -
NEW MEMBER: Have Built 2 CNC machines 1 mill/drill conversion and 1 Router/plasma from scratch
By AGB in forum New Member IntroductionsReplies: 3Last Post: 06-02-2013, 03:16 AM -
Hypertherm Duramax Torches to upgrade Powermax 1000 & Powermax 1250
By Hypertherm John in forum Manufacturer NewsReplies: 0Last Post: 04-03-2011, 03:26 PM -
Building from Scratch or follow some plans?
By Monk in forum Gantry/Router Machines & BuildingReplies: 22Last Post: 12-08-2010, 10:27 PM -
Need helpwiring up from scratch
By GeorgeD in forum Machine DiscussionReplies: 40Last Post: 13-07-2010, 06:23 PM
