Quote Originally Posted by Danielroyal25 View Post
Yeah definitely want to get the CAD model 100% before ordering anything, as it will be a costly error!
Yes and NO.?? . . . Draw the layout in cad to get the general machine design but don't order anything off the back of measurements taken from it other wise you will cock up somewhere.
Unless you have used models that have very accurate dimensions then your much better ordering important or components with critical dimensions has you go along taking measurements direct from the frame and machine has it's coming together.
Often you'll see people buy everything before starting only to find something is too long or too short or completely wrong and won't fit.!!
Components from Chai usually arrive in about 12days and within a day or so of starting the frame you'll have enough information to confidently measure from and order parts knowing they will fit exactly with no guessing or nasty surprises.
By the time you have finished welding or bolting the frame together they will have arrived and ready to fit.
The motors and drives I would buy from Zapp or cncdiy because you'll have backup and easy UK return if faulty. Again don't buy until your ready and need them.?
While it's seems nice to have them and spin them up on the bench etc in reality all your doing is wasting warranty and the Electronics are one of the last things you need. There's also the chance of new or better models being available for the same or less money by the time you actually do need them. The digital drive market is constantly evolving and getting cheaper each month.
DONT BUY the cheap 3 AXIS boards from Ebay you'll just be buying trouble and rubbish performance.
You want separate drives and if you can afford them I'd recommend digital drives. Also very important that you match the power supply(PSU) to the motors and drives.
Watch out for Kits that are sold because they have a nasty habit of bundling low voltage PSU's. Often it's cheaper and better to build your own if needing more than 50-60V
Getting the Voltage right is the key a to good running machine and often folks use to low PSU and don't take advantage of the machines full potential.
Also don't be afraid to over spec on the drives.? By this I mean if you can afford 80v drives over 50V then do so. You don't have to run them at 80V and having the overhead gives advantages. Firstly you have upgrade ability but more so they are not being constantly run close to there maximum capability's so are under less stress and will last longer.
Often folks will buy 50V drives and correctly run them at 45-46V but that means the internal electronics are constantly near there max ability with only a small margin of over head. Anything that easily handles the loads they carry will last longer, yes initially they cost more but it will be returned thru reliability and longevity in the long run.
Another often done thing.?? . . Don't go buying massive motors like 12NM nema 34's etc 3Nm nema 23 will be more than enough for this size type machine and cheap.
Regards the frame then it needs some diagonal bracing and if it's an adjustable bed which it looks then it needs much more support for the sides. Don't rely on the bed to for rigidity or strength, which it will do anyway, because when you come to adjust the bed the frame will move and flex knocking alignment and setup out every time.
This will be a real pain, also the frame will be flimsy and resonant which will affect cut quality.
Don't be skimpy on the frame Chunky is good, same with gantry don't be afraid of bit of weight it helps with cut quality and you'll be surprised how powerful the combination of ballscrews and steppers can be.!!
Hope this helps.
