    Thanks for the info guys!
    Just wanted to give some more info on the use of the machine and the design so far.
    Im hoping to cut mainly large ply / MDF sheets on it so wanted it to accommodate the maximum capacity sheet (standard size: 8ft x 4ft).
    i didnt want to build a router to this overall sheet size as i it will be a bit of a beast and also the cost comes into play. my thoughts were to make it accept the width of the sheet (4ft / 1220mm + a little) and then the length of the board could be machined in two halves by either feeding the material through of turning it through 180 degrees.
    Does the length of the gantry pose a problem for general machining and would it be able to handle cutting aluminium? As long as the strength is there will it be ok and will the precision still be to a fairly high standard. If cutting aluminium or harder woods is
    Will be looking at getting the water cooled spindle so im guessing the weight of the gantry and Z axis will be a fair bit so the gantry will have to be fairly substantial.
    The bed is going to be in a fixed position so this can be bulked up with diagonals for strength and like suggested heavier gauge extrusion, just difficult to balance the desired design with the cost of parts.
    The support in the Y direction behind the gantry was to mount the motor in the centre with pulleys to the X ballscrews, so didnt really want to add a support the other end as this was to allow material to be fed in / out but if i can position it in a way that the material can be slid under the support i may add this in.
    Quote Originally Posted by Danielroyal25 View Post
    Yes Gantry length will greatly affect the machine but not so much for precision but more the quality of finish from machine. Precison or accurecy is down to combination of components and quality of build.
    That doesn't mean you can't have long gantry but it does mean it will have to be very strong and substantial to resist resonance and flex which are the enemy of finish quality.
    Take this strength to another level if you want to cut Aluminium and achieve good Finish quality. Really unless your only cutting Thin Alu sheet or Profiles etc that don't need good finish then forget cutting Aluminium on such a wide or long moving gantry machine. Yes it will do it but not very well.!!
    No need One end support will be fine so long the frame is braced well, my machine has this one end setup and it works fine.
    If your into wood can I suggest you have the rails slightly overhang the end of bed. Doing this simple thing will give you some nice options easily achieved.
    Namely will allow end machining of boards etc for hinges, locks, Dovetails and oversize or oversize awkward parts by clamping to end of machine.
    Also if you want a 4th axis makes it very easy to add one see pics for some idea of what I mean.
    It's only a cad mock up so pay no attention to details like gantry has thats actually a design I use the other way round it just saved me some drawing time for showing the person it was intended for. It could be used that way round thou.!!
ID:	8151   Click image for larger version.
ID:	8152   Click image for larger version.
ID:	8153   Click image for larger version.
ID:	8154   Click image for larger version.
ID:	8155   Click image for larger version.
ID:	8156   Click image for larger version.
  1. BUILD LOG: starting from scratch- router 1st project
    By idefix in forum DIY Router Build Logs
    Last Post: 10-01-2014, 12:53 AM
  2. NEW MEMBER: Have Built 2 CNC machines 1 mill/drill conversion and 1 Router/plasma from scratch
    By AGB in forum New Member Introductions
    Last Post: 06-02-2013, 03:16 AM
  3. Hypertherm Duramax Torches to upgrade Powermax 1000 & Powermax 1250
    By Hypertherm John in forum Manufacturer News
    Last Post: 04-03-2011, 03:26 PM
  4. Building from Scratch or follow some plans?
    By Monk in forum Gantry/Router Machines & Building
    Last Post: 12-08-2010, 10:27 PM
  5. Need helpwiring up from scratch
    By GeorgeD in forum Machine Discussion
    Last Post: 13-07-2010, 06:23 PM
