Thread: setting the origin
Have to agree with it depends and John S pointing out some of the reasons. If it setting up a part on the deck that is NOT going on a preset jig I set up to the material and then add offset to get the bit where I want it (usually .5 to .75 diameter of the largest bit being used) unless there is a built in offset in the project or I have to put in a larger offset due to needing material edge that needs to be remaining. I use G55 to G57 for most of these and they get changed as needed. For Jig stations where the Jig has been placed and is squared and the material is a fixed to the jig; then I use the preset G59P# depending on which station I am using (start at P7). This probably is as clear as mud and hope I am not just making it worse.
Tool offset I deal with in my CAM programs so that issue does not become a problem when dealing with the machining side of the item. CAD wise it depends if I am planning to offset the item and we are back to same issue as above. I tend to work from 0,0,0 in CAD and then adjust once in my CAM program IF I am going or need to.
Michael
Setting my table up...
By Davek0974 in forum Plasma Table MachinesReplies: 23Last Post: 10-03-2014, 08:24 PM -
setting up a business
By dstivens in forum Opportunities Available & SoughtReplies: 5Last Post: 16-05-2013, 10:28 PM -
hi i nead help please with setting up dsp control
By cockneyrebel in forum Machine Control SoftwareReplies: 1Last Post: 19-01-2013, 01:18 AM -
Setting a start point.
By jrob3rts in forum Computer SoftwareReplies: 14Last Post: 17-06-2012, 12:36 PM -
Need help setting up a CNC router machine please
By 1albobs in forum Gantry/Router Machines & BuildingReplies: 4Last Post: 27-02-2012, 06:16 PM
