31-01-2013 #2
31-01-2013 #3
What have you currently got the ramp up/down (PD14,PD15) times set to? I don't remember exactly (will check), but I set mine to no more than a couple of seconds and it's fine. If the acceleration is set too high the DC bus voltage in the VFD will get too high, and the inverter will cut out for protection so it's very unlikely to break anything. Try changing it gradually...
On a machine with gearing etc, like a lathe, it's not sensible to set the ramp up time to something very high, since it would just wearing out the gearbox unnecessarily.
31-01-2013 #4
31-01-2013 #5
I was referring to both the ramp up and down settings, so clearly that comment is regarding negative acceleration...
If the user is using the original motor, then it's not much different, however it's not uncommon for people to get a bigger motor than the machine was designed for, which could potentially achieve higher acceleration than the original motor. I guess it was hardly worth mentioning in this context. Also, in general it is sensible to warn to be conservative with these settings as they could cause problems later on - for instance on a lathe swapping to a larger chuck or faceplate can greatly increase the inertia (due to power 4 relationship) and as a result cause the drive to cut out.
31-01-2013 #6
Better letting Mach do it because then if for instance you use G-code that hasn't come from your Cam or Post chances are it won't have G4 dwell command, then your pissing about editing the Code. No big deal to do but could be if you forget and delv the cutter into material before up to speed.!!
Simple O-ring calculator.
By jcb121 in forum General ComputingReplies: 4Last Post: 26-07-2013, 09:00 PM -
RFQ: Simple job cutting simple shapes out of camera lens cap
By RockandGrohl in forum Projects, Jobs & RequestsReplies: 15Last Post: 20-04-2013, 01:23 AM -
RFQ: Very simple small part
By Shinobiwan in forum Projects, Jobs & RequestsReplies: 5Last Post: 11-01-2013, 01:02 AM -
Machine co-ordinates button in Mach 3
By alan2525 in forum Artsoft Mach (3 & 4)Replies: 1Last Post: 14-04-2010, 10:57 PM -
why is nothing in life simple!
By ptjw7uk in forum General DiscussionReplies: 7Last Post: 08-07-2009, 09:21 PM
