30-01-2013 #3
Mach3 without the licence will allow up to 500 lines of code, but the line you've quoted is line 152 in your file, so it doesn't look like that's the problem. Just to be sure though, in mach3 goto 'help' then 'about' and see what it says under 'Licenced to'. I don't think there's anything wrong with that particular line, since for instance it's identical to line 15 (N65).
It wont help with the current problem, but either way try putting G64 at the beginning of the code. This will make the machine run in 'constant velocity' mode, instead of 'exact stop' (G61) which causes it to move exactly through each co-ordinate which often makes the motion not very smooth.
Simple O-ring calculator.
By jcb121 in forum General ComputingReplies: 4Last Post: 26-07-2013, 09:00 PM -
RFQ: Simple job cutting simple shapes out of camera lens cap
By RockandGrohl in forum Projects, Jobs & RequestsReplies: 15Last Post: 20-04-2013, 01:23 AM -
RFQ: Very simple small part
By Shinobiwan in forum Projects, Jobs & RequestsReplies: 5Last Post: 11-01-2013, 01:02 AM -
Machine co-ordinates button in Mach 3
By alan2525 in forum Artsoft Mach (3 & 4)Replies: 1Last Post: 14-04-2010, 10:57 PM -
why is nothing in life simple!
By ptjw7uk in forum General DiscussionReplies: 7Last Post: 08-07-2009, 09:21 PM
