    Quote Originally Posted by Shinobiwan View Post
    Also how do I set my dwell time? The spindle take a few seconds to get up to speed and Mach is wanting to get going before its ready. Could be problem if its trying to cut whilst still spinning up.
    Ports&pins/spindle setup then General parameters CW delay. . . . OR possibly need to set the ramp up time on the VFD.?
    You would want spindle reverse if you was doing rigid tapping and things like that.!
    Cheers mate.
    Remember its one of those shitty Chinese VFD's so it'd probably blow a capacitor or something if you tried to up the ramp time lol Safer to do it in software.
    I have added a line in my post to include an G04 P4 right after the G3 but your way looks better.
    Cheers mate.
    I have added a line in my post to include an G04 P4 right after the G3 .
    Been doing this for ages, big CNC has a 7 HP motor on it and it takes a couple of seconds for it to spool up.
    John S -
    Cheers mate.
    What have you currently got the ramp up/down (PD14,PD15) times set to? I don't remember exactly (will check), but I set mine to no more than a couple of seconds and it's fine. If the acceleration is set too high the DC bus voltage in the VFD will get too high, and the inverter will cut out for protection so it's very unlikely to break anything. Try changing it gradually...
    On a machine with gearing etc, like a lathe, it's not sensible to set the ramp up time to something very high, since it would just wearing out the gearbox unnecessarily.
    Lives in East Lothian, United Kingdom. Last Activity: 6 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,994. Received thanks 376 times, giving thanks to others 9 times.
    How will accelerating too fast cause the DC bus to go overvoltage?
    Also, how is accelerating a geared machine too quickly with a VFD any different from turning the motor on with a switch?
    I was referring to both the ramp up and down settings, so clearly that comment is regarding negative acceleration...
    If the user is using the original motor, then it's not much different, however it's not uncommon for people to get a bigger motor than the machine was designed for, which could potentially achieve higher acceleration than the original motor. I guess it was hardly worth mentioning in this context. Also, in general it is sensible to warn to be conservative with these settings as they could cause problems later on - for instance on a lathe swapping to a larger chuck or faceplate can greatly increase the inertia (due to power 4 relationship) and as a result cause the drive to cut out.
    Better letting Mach do it because then if for instance you use G-code that hasn't come from your Cam or Post chances are it won't have G4 dwell command, then your pissing about editing the Code. No big deal to do but could be if you forget and delv the cutter into material before up to speed.!!
  1. Simple O-ring calculator.
    By jcb121 in forum General Computing
    Last Post: 26-07-2013, 09:00 PM
  2. RFQ: Simple job cutting simple shapes out of camera lens cap
    By RockandGrohl in forum Projects, Jobs & Requests
    Last Post: 20-04-2013, 01:23 AM
  3. RFQ: Very simple small part
    By Shinobiwan in forum Projects, Jobs & Requests
    Last Post: 11-01-2013, 01:02 AM
  4. Machine co-ordinates button in Mach 3
    By alan2525 in forum Artsoft Mach (3 & 4)
    Last Post: 14-04-2010, 10:57 PM
  5. why is nothing in life simple!
    By ptjw7uk in forum General Discussion
    Last Post: 08-07-2009, 09:21 PM
