Quote Originally Posted by i2i View Post
Jazz, the spindle board has 2 polyester film caps on it that fail all the time, replace them with modern equivalents and it should work again.
They look ok but will do for the little they cost. Thou to be honest the bloody thing lit up like a Xmas tree for the fraction of second it took to hit E-stop and the sparks and smoke seemed like it came from below the heat sink plate near the Big diode.
The stepper drives are probably only run on 24v, so they could do with upgrading. Are they black heatsinked blocks or passive open board types.
Seen that the CNC doctor shows the my setup has Half step unipolar drives. I've ripped the drives(passive) out already which used approx 28V and will be using some modern drives, probably M542.
The steppers are 8 wire so I'll probably wire them Bipolar parallel but not sure on Amps or how much voltage they'll handle. I've got a 42-44V supply I'd like to use but think those little motors may not like that much but with a bit of trial and error I could figure that out but if someone had already used modern drive would save me the hassle.!!
