Thread: Cut quality
	04-02-2013 #11
looks like you need to hurry up and sell some stuff... chewing on aluminium cant be good for your teeth..
	04-02-2013 #12
The chips aint too bad with a bit of warm milk!
I really do need to get them sorted out out and sold off. Had them for a while now and havent gotten round to it. Thats what I get for doing non paying jobs I suppose.
	04-02-2013 #13
As others have said, looks like chip recutting.
Did you run a spring/reflex cut to finish? If not this may help tidy it up a bit, depending how deep the damage at the top is.
	04-02-2013 #14
	04-02-2013 #15
A spring cut is when you run the cutter around the part again after your finish cut so that the cutter isn't under any load.
	04-02-2013 #16
Silly question, but. What's the flute length of your cutter?
	04-02-2013 #17
Have you tried climb milling on your finishing pass? G.
	04-02-2013 #18
Oscar the cutter flute length is 27mm.
Geoffrey I would need to check the file to see how it was milled. Does climb milling improve the surface finish much?
	04-02-2013 #19
	04-02-2013 #20
I climb mill on everything, can't remember the last time I didn't. The finish is always good, if everything is set correctly. Also if the cutter does deflect its pushed away from the part, leaving metal safe (nothing a spring cut wont sort out). Rather than conventional milling where the cutter can pull into the job making it undersized.
Good quality pillar drill?
By newtoid1986 in forum Machine DiscussionReplies: 6Last Post: 19-04-2013, 01:40 PM -
Quality DTI - Manufacturers
By dsc in forum Marketplace DiscussionReplies: 8Last Post: 13-12-2012, 01:34 PM -
stainless steel fasteners - quality
By dsc in forum Metalwork DiscussionReplies: 7Last Post: 30-11-2012, 12:35 PM -
CMM Programmer/Quality Engineer
By Excel in forum Opportunities Available & SoughtReplies: 0Last Post: 22-02-2011, 05:57 PM -
NEW MEMBER: cubikoman needs to improve quality of his boardgame
By cubikoman in forum New Member IntroductionsReplies: 2Last Post: 16-02-2011, 12:17 PM
