Thread: Sooo much to learn...
Hello techcobweb: We all have "soo much to learn!" However, you have a lot going for you. It takes a lot of effort to build a cnc machine from scratch but it all starts with a plan. Make it a simple plan. I started with a design of the basic components in Microsoft Powerpoint and dedicated individual slides for the components (now I have BobCad-Cam). Since you'll be working with wood, a consideration for the machine material could be aluminum. I have an old drill press, a 10" mitter saw with a metal cutting disk and a small vise attached to it to hold the plates, drills and taps. There are low temperature aluminum welding rods you could use to weld the parts together using a propane torch (I haven't tried them). But, along the way, you'll find a machine shop that might allow you to use/rent a milling machine for some of the more precise parts (that's what happened to me). That's another thing to learn! In regards to the cold weather, I can only offer to send you a bottle of our hot Southern Florida sun! Good luck
NEW MEMBER: New Member desperate to learn
By Mill Grav Newbie in forum New Member IntroductionsReplies: 3Last Post: 24-04-2012, 01:17 PM -
Learn the truth about BobCAD-CAM
By aldepoalo in forum BobCAD-CAMReplies: 0Last Post: 13-04-2012, 04:12 PM -
NEW MEMBER: Here to learn
By Mjolinor in forum New Member IntroductionsReplies: 0Last Post: 06-09-2011, 07:56 PM -
By Pol in forum New Member IntroductionsReplies: 0Last Post: 11-08-2011, 02:50 PM -
Where did you learn electronics?
By AlexBanich in forum General ElectronicsReplies: 13Last Post: 29-07-2009, 03:22 PM
