ID:	8163Click image for larger version.
ID:	8164Click image for larger version.
    EBAY ( its goes live at 22:00 6th feb )
    Less than 12 months old, degassing chamber. New cost £280
    Robinair RA15601 6CFM was £320 new.
    *********** Collection is encouraged as these Items are heavy and you will save on the transport/shipping costs. ******************
    This has been the best combination I have had so far as degassing chamber and pump, the chamber seals tight instantly the vacuum starts and the Robinair takes the vacuum to 30 hg and below in 5 – 6 seconds, then holds the vacuum fast. I’m only selling it because I need a larger chamber. All the coupling’s pipes gauges come with it. All you need to do is connect the pipe and plug it in and instant vacuum ( you also need electricity to power the pump lol ) Chamber has a clear acrylic top so you can see you resin – rtv etc bubbling and the valve handles means you can let in air if the degassing is to vigorous instantly ( stop it spilling over), takes a couple of tries to know how much you materials need but you soon get the hang of it. Vacuum releases in less than a second so no time wasting with quick cure resins.
    “This is about the degassing chamber from the guy I bought it from –
    Degassing / Vacuum Chamber 10 ltr
    The chamber is 225mm in diameter, 260mm deep and has a 20mm clear acrylic top. It is constructed with a 6mm steel base (with a layer of rubber on the base) and a 12mm thick nylon tube, with a rubber gasket on the top, to insure a good seal against the acrylic top. The benefit of using the nylon is its translucency. It let’s in more light than other chambers on the market, thereby allowing the user to see inside with ease. It also comes with a length of hose, a dial gauge, a right angle hose fitting and a small tube of silicone grease (to aid the seal between the acrylic top and the rubber)
    Please note: There are some scratches on the surface of the nylon tube, this is from the manufacture of the tube and are purely cosmetic and won't affect the performance of the Vacuum chamber."
    Robinair RA15601
    High quality 6CFM vacuum pump
    • Two stage design – second stage starts pumping at a lower pressure to pull a deeper ultimate vacuum
    • Offset rotary vanes – proven design creates the deep vacuum conditions needed for a thorough evacuation
    • Gas ballast feature – helps keep the pump oil clean by reducing condensation of moisture
    • Iso-Valve – isolates pump from the system with just a 1/4 turn, making it simple to measure rate of rise
    Ralph Waldo Emerson
  1. FOR SALE: Delta pump
    By onecut in forum Items For Sale
    Last Post: 15-05-2014, 02:59 PM
  2. Vacuum pump for a large matrix bed cnc 5 by 10 foot
    By gavztheouch in forum General Electronics
    Last Post: 03-11-2013, 06:01 PM
  3. Spindle Water Pump
    By Tomnewry in forum Spindles & Drive Motors
    Last Post: 11-08-2013, 01:05 PM
  4. SAE thread fittings Vacuum Pump
    By Bazzer in forum Marketplace Discussion
    Last Post: 27-05-2013, 12:02 AM
  5. Machine oil pump
    By cncezee in forum Milling Machines, Builds & Conversions
    Last Post: 24-11-2010, 05:00 PM
