    I'm sure this must be an obvious thing but a quick Google didn't tell me. How can I add a message to G-Code that will be displayed when running the code? I want to do a machine stop for a manual tool change and it would be nice for it to remind me what tool and what RPM to use.
    Mach3 has a little text prompt where it gives errors and tells you when it is in E-Stop etc.. I assume text can be made to display here from the code.
    Lives in East Lothian, United Kingdom. Last Activity: 10 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,990. Received thanks 374 times, giving thanks to others 9 times.
    Just add a comment in brackets on the line of the code you want the message displayed, i.e.-
    T0101 (comment to tell me to fit tool 1)
    Ah-ha! In Dolphin you can add your own line entry to the code by clicking 'Insert' under the machining menu. Then for Mach3 you simply need to put brackets (...) around what you want to say and it will be a comment that pops up at he bottom of the screen :)
    Thanks M_C I got there :)
    For anyone who uses LinuxCNC you can insert the following comment:
    (msg, your message here)
    Then it will display everything after the comma as a message.
    Ah ah can tell You've been playing with them lathes too much. . .Lol ( T0101 is tool number for lathes)
    Je n'ais comprende mill
  1. eazicnc 3 'SAFETY' message
    By makman in forum General Discussion
    Last Post: 28-01-2019, 09:14 AM
  2. How to find first job as CNC operator ?
    By malzyk in forum Opportunities Available & Sought
    Last Post: 07-09-2013, 04:21 PM
  3. Message for member SMASH
    By birchy in forum General Discussion
    Last Post: 07-08-2013, 09:40 AM
  4. Cambium Code Web Tools – Parametric G-code Generation
    By CambiumMachines in forum Manufacturer News
    Last Post: 09-01-2013, 04:56 AM
  5. NEW MEMBER: hello a cnc operator here...
    By whz1001 in forum New Member Introductions
    Last Post: 29-05-2012, 11:05 AM
