09-02-2013 #7
Cutting speeds you work out from feed per tooth/insert, which varies depending on tools and materials. You then multiply the No.of Teeth x RPM x feed per tooth to give you the feed rate,.
However you'll first have to work out RPM from the recommended cutting speeds and cutter diameter.
The best option is find a tooling catalogue, look at some of the more common tools/inserts, and do some calculations.
Programming Denford TRIAC from a drawing !
By edwardsjc in forum Machine Control SoftwareReplies: 1Last Post: 15-03-2012, 09:29 PM -
NEW MEMBER: Fanuc Macro programming
By curly3456 in forum New Member IntroductionsReplies: 0Last Post: 02-02-2012, 10:20 PM -
Difference between controllers and Cad/Cam programming???
By 0625272 in forum Computer SoftwareReplies: 0Last Post: 23-06-2011, 08:40 PM -
Programming an engraver
By patch in forum Computer SoftwareReplies: 2Last Post: 24-11-2009, 10:11 PM -
Programming Mach3 screens
By Smiler in forum Artsoft Mach (3 & 4)Replies: 7Last Post: 17-01-2009, 03:15 AM
