Thread: Aluminium Kress Spindle Holder
14-02-2009 #1
Material and setup
I opted to use 12MM aluminium for this. It is 95MM wide and over 100MM long.
The spindle holder needs approx 85MM * 85MM, so allow for the extra being cut out.
I already had a bit of levelled MDF still on the bed, so simply drilled 4 holes in each corner of the aluminium block and secured it nice and tight to the bed.
As you can see the usual yellow pipe for extracting the waste is attached but also this time I have attached an airline coming from the compressor. I am hoping the airline will help keep the cutting bit cool and also blow any waste away from the cutting area.
The cutting bit I am using is a 3mm carbide 2 flute slotted drill. The flute on these nice little cutters should clear the waste away and also be tough enough for the job.
Artwork
Find the design and Gcode below, that you are more than welcome to use.
The design above has a 44MM hole in the middle which can then be clamped up a little by the two top tabs.
This design will fit the Z-Axis on our machine just like the normal spindle holders we supply for the Mini Spindle.
It will cut down at 0.30 MM a step and run at 50MM per minute.
Okay so not the fastest cutting speed, but I am in no hurry and do not want to overload the small Mini Spindle.
I have no doughts about cutting Aluminium with the machine as the frame is more than rigid enough, my concern is with the Mini Spindle being man enough and this is one of the reasons I am choosing to upgrade to the Kress.
Also the 3mm 2 flute bits have a 12mm cutting flute length, so it gonna get tricky near the bottom.
It will go all the way down to 13MM, so just Zero the X and Y to the bottom left of your workpiece and the Z-Axis on top of your workpiece.
Please right click and choose save to download the Gcode.
Please Click here to download the Gcode
Milling the Aluminium block.
Above you can see it cutting with the airline doing the job of keeping it clear.
My little compressor tends to overheat if left running all the time, So I kept the air flow to as small as I could, so it would not empty the tank too fast.
As you can see the 3mm 2 flute cutting bit does indeed glide through and leaves a nice finish with dry cutting.
Finished piece.
Well here it is, the finished piece. It did struggle a little after getting past 10MM deep with the noise increasing, but it did it.
I do not think I would attempt again to cut aluminium this thick with the Mini Spindle as too slow, but watch out for some new examples of aluminium block now I can use my Kress Spindle!
Top of finished Workpiecebottom of finished Workpiece
All I need to do now is drill a hole through the top clamp and two holes in the bottom so I can connect it to my machine.
Above shows the Spindle holder in place and it is more than secure with no play.
This was pulled from: http://www.cncdudez.co.uk/Lee
14-02-2009 #2
One note.
The Kress has a 43mm spigot at the end not 44mm.
John S.
14-02-2009 #3
True they will but why not do it right in the first place and not reply on a two point contact that can rock and induce errors into the work ?
The problem with the Internet is the speed it transmits information, good or bad and in most cases it gets to stay permanent.
We now have two sites [ at least ] saying a Kress has a 44mm spigot when it doesn't.
John S
[ who makes commercial Kress holders with the correct size hole and no it's not sour grapes as I don't sell them privately, only to larger OEM's ]
14-02-2009 #4
Yes i noticed that as well john, i'm redesigning a mount today in the right sizes. can you help me with any formulations and/or mathmatics that i should be using to make a spindle mount.
I was hoping to use 16mm Thick ali, 6082T6 grade. i will post up some art once i get started, what i'm concerned about is how much matrial i should leave for the area around the part that clamps to the spigot on the spindle.
also john would you be ok posting your design for our review, would be nice to see how you have gone about designing yours.
Thanks,
LeeLee
14-02-2009 #5
As long as you are working on the right size hole, 43mm, the the shape doesn't matter as it has to deform only very slightly to grip the Kress.
My ' design' is based on a piece of 20mm thick 100mm wide alloy split thru into the hole at the front and a clamp screw fitted.
Even though this is very substantial it still grips the Kress hard, if it was 1mm oversize then I don't think it would deform enough to hold it securely hence getting it right to start with.
My design will not suit many as it's purposely over length as it has to reach on the OEM machine.
It also doesn't bolt onto the Z axis but fits on a quick release mounting so the original machine has a choice of three spindle alternatives.
14-02-2009 #6
Ok john ill crack on with the one i'm designing and post it up for your review. Thanks mate, Lee
John, is there a standard centre size for mounting holes on a spindle mount?
I noticed MD is selling spindle holders with 52mm centres and also 90mm centres for the mounting holes.
The spindle mount on my machine has 60mm centres.
Thanks,
LeeLee
05-03-2009 #8
Wickes used to sell those Kress Spindles (model FM 6990 E) as their "own brand" routers, you can sometimes get them cheap on E-bay. I got two for my CNC router, and some extra collet nuts and collets from http://www.cncplus.de
05-03-2009 #9
06-03-2009 #10
Yes that's mine. I just moved house and It's been sitting in the garage under a pile of stuff for a year. I got it going again last week and I was going to use it cut out a new machine, but I think I'll just stick with this one for a while. Making the machines is so much fun that you can easily get caught with making the next one, rather than using it to make something useful!
machining aluminium with 1.5kW spindle
By routercnc in forum Spindles & Drive MotorsReplies: 13Last Post: 15-02-2014, 02:55 AM -
eBay: Kress 1050 FME-1 Spindle
By viz in forum Items On eBay UKReplies: 0Last Post: 21-08-2013, 04:04 PM -
WANTED: Spindle holder for 1.5kw Chinese spindle.
By jcb121 in forum Items WantedReplies: 19Last Post: 14-10-2011, 02:07 PM -
Secondary Kress spindle mount.. Does it exist?
By fasteddy in forum Kress Milling MotorsReplies: 6Last Post: 18-08-2010, 05:25 PM -
By GTJim in forum Kress Milling MotorsReplies: 7Last Post: 25-05-2009, 07:02 PM
