Thread: Speeds and feeds deep drilling
Taking a decent cut of metal will of made a big difference.
If you don't take a deep enough cut, the heat builds up at the tip, leading to work hardening, and chip build up on the drill, which then reduces cutting effiency further.
It's best to look at the speeds/feeds for what you're using, and work out what the limiting factor of your machine is. Mostly in aluminium, spindle speed is the limiting factor.
Feeds and speeds
By dudz in forum Tool & Tooling TechnologyReplies: 0Last Post: 26-08-2013, 11:42 AM -
Engineering Calculators - speeds, feeds, torque, etc.
By birchy in forum Machine DiscussionReplies: 0Last Post: 16-06-2013, 01:42 PM -
Advice needed on feeds and speeds!
By lateAtNight in forum Machine DiscussionReplies: 5Last Post: 14-11-2012, 12:47 PM -
Speeds and Feeds
By Web Goblin in forum Tool & Tooling TechnologyReplies: 0Last Post: 20-09-2012, 01:38 PM -
How deep can i cut MDF?
By MrWiz73 in forum Machine DiscussionReplies: 6Last Post: 24-08-2011, 10:38 PM
