    dsc's Avatar
    Lives in Lincoln, United Kingdom. Last Activity: 17-06-2020 Has been a member for 9-10 years. Has a total post count of 252. Received thanks 1 times, giving thanks to others 11 times.
    Gents,
    I'm trying to calculate the maximum deflection of an unsupported part of a shaft with the following data:
    L total unsupported length = 0.18m (not mm;))
    A cross section surface (round rod) = pi * (0.01m)^2
    E Young's modulus = 180GPa
    F force applied to the end of shaft = 1000N (random round number)
    delta (max deflection) = F*L / E*A
    Now popping the values in to the equation I get that max deflection is equal:
    delta = F * 3.19*10^-9 [m/N]
    which basically means that with F = 1000N the deflection is
    delta = 3.19 * 10^-6 m = 3.19*10^-3 mm = 0.00319mm
    That is rather small, considering that 1000N is pretty much the same as 100kg weight attached to one end.
    Pack of biscuits to anyone who can point an error in the above and call be stupid:)
    Regards,
    dsc.
    Lives in East Lothian, United Kingdom. Last Activity: 6 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,994. Received thanks 376 times, giving thanks to others 9 times.
    0.18mm unsupported length?
    dsc's Avatar
    Ha, well spotted, although it's just a unit error.
    After some reading I don't think the above equation for delta is correct as there's no moment of inertia involved.
    Regards,
    dsc.
    I just ran the figures and got 3183mm of deflection...
    A = pi0.01^2 = 0.000314159
    F*L = 1000 * 0.18 = 180
    E*A = 180 * 0.0003blahblah = 0.05654866
    180 / 0.0565blahblah = 3183.09886183
    Perhaps you are working out how far it will stretch if you pull on the end, not how far it will bend if you load it at 90 degrees?
    You could be right here Robin. Its been a very long time since I used Youngs Modulus but in this form I thought it was used for calculating a change in length due to compression or extension.
    dsc's Avatar
    Ah yes, it's all wrong!:)
    Here's the right formula (taken from http://www.clag.org.uk/beam.html):
    δ = FL3 ∕ 3EI
    I = πr4 ∕ 4 = πd4 ∕ 64
    (for round beam)
    which means that deflection at a given F and L, for a 20mm dia beam is:
    δ = FL3 * 0.0002358
    Assuming L = 0.18m and F=100N the maximum deflection is:
    δ = 100 * 0.005832 * 0.0002358 m = 0.0001375m = 0.1375mm
    Which makes much more sense than the previously calculated value.
    The funny thing is that changing the dia from 20mm to 22mm gives you a maximum deflection drop from 0.1375mm to 0.094mm. That's just by making the shaft 2mm thicker. Quite amazing me thinks.
    Regards,
    dsc.
  1. How much deflection to expect...
    By Wal in forum Gantry/Router Machines & Building
    Last Post: 04-02-2014, 10:41 AM
  2. screening / glitchy operation - sanity check
    By dsc in forum General Electronics
    Last Post: 01-12-2013, 11:35 PM
  3. sanity check - constant running, loads and more
    By dsc in forum Stepper & Servo Motors
    Last Post: 26-11-2012, 12:26 PM
  4. Toroidal transformer voltages - sanity check needed!
    By m_c in forum General Electronics
    Last Post: 03-10-2011, 08:34 PM
  5. Deflection in precision rod rails
    By irving2008 in forum Rails, Guideways & Bearings
    Last Post: 14-03-2009, 12:01 PM
