Ah yes, it's all wrong!:)
Here's the right formula (taken from http://www.clag.org.uk/beam.html):
δ = FL3 ∕ 3EI
I = πr4 ∕ 4 = πd4 ∕ 64
(for round beam)
which means that deflection at a given F and L, for a 20mm dia beam is:
δ = FL3 * 0.0002358
Assuming L = 0.18m and F=100N the maximum deflection is:
δ = 100 * 0.005832 * 0.0002358 m = 0.0001375m = 0.1375mm
Which makes much more sense than the previously calculated value.
The funny thing is that changing the dia from 20mm to 22mm gives you a maximum deflection drop from 0.1375mm to 0.094mm. That's just by making the shaft 2mm thicker. Quite amazing me thinks.
Regards,
dsc.
How much deflection to expect...
By Wal in forum Gantry/Router Machines & BuildingReplies: 30Last Post: 04-02-2014, 10:41 AM -
screening / glitchy operation - sanity check
By dsc in forum General ElectronicsReplies: 21Last Post: 01-12-2013, 11:35 PM -
sanity check - constant running, loads and more
By dsc in forum Stepper & Servo MotorsReplies: 4Last Post: 26-11-2012, 12:26 PM -
Toroidal transformer voltages - sanity check needed!
By m_c in forum General ElectronicsReplies: 16Last Post: 03-10-2011, 08:34 PM -
Deflection in precision rod rails
By irving2008 in forum Rails, Guideways & BearingsReplies: 11Last Post: 14-03-2009, 12:01 PM
