13-02-2013 #11
I bought this and cut a basic mdf dust skirt, and cable tied it to spindle, seems to work ok
PU Flexible Ducting Hose - Ventilation, Fume&Dust Extraction, Woodworking | eBay
13-02-2013 #12
Thanks guys for the suggestions :) Wify I don't think that stuff holds its shape ? Like I said Ill go to B&Q and use the flexi lamp tube, if its thick enough or maybe atempt wrapping some wire round a tube as suggested.
Ralph Waldo Emerson
13-02-2013 #13
Does it have to be stainless steel, how about a bit of copper pipe 22 or 28mm with soldered bends or bent with a spring or pipe bender ? You can then use plastic clips to hold it in place.
Cheers,
Rob
13-02-2013 #14
14-02-2013 #15
You could try some Kopex flexible conduit. This wont hold its shape on its own but covering it in some heat shrink when its shaped should stiffen it up quite a bit.
14-02-2013 #16
What I would like to do is adjust it on the fly .. that's why I like the idea of the goose-neck stuff, so I can manipulate it to get the maximum draw.
Ralph Waldo Emerson
Need help, buy or build to cut steel, stainless steel, titanium etc
By fatguyslim in forum Machine DiscussionReplies: 41Last Post: 08-02-2014, 11:37 PM -
RFQ: Require small Stainless steel buckles machining- can you help please ?
By Gasgasbones in forum Projects, Jobs & RequestsReplies: 0Last Post: 15-05-2013, 06:47 AM -
RFQ: RFQ: Micro Precision in Stainless Steel.
By mikewatch in forum Projects, Jobs & RequestsReplies: 3Last Post: 12-04-2013, 11:49 PM -
What kind of machine will do stainless steel or brass engraving
By JayPunchbuggy in forum Machine DiscussionReplies: 8Last Post: 13-03-2013, 10:40 PM -
stainless steel fasteners - quality
By dsc in forum Metalwork DiscussionReplies: 7Last Post: 30-11-2012, 12:35 PM
