18-02-2013 #1
As my CNC machine is not yet finished (or even 100% designed!) I require the following...
I am looking for the following part to be machined out of aluminium (Qty 2, T6 or similar). The counterbores may cause an issue (thin wall between counterbore and 6mm diameter hole next to it) but I can afford not to have them if they are not machinable. See image below.
I am also looking for some lathe work where I require some small plastic spur gears to have the bore increased. There may be issues with how the spur is held in the chuck but I am hoping it is possible! Again, image below :)
Obviously willing to pay the going rate.
Cheers,
Dave
18-02-2013 #2
I Can do them for you no problem, Drop me an email to sales (at) protocnc.co.uk
Regards
Adam
The Following User Says Thank You to AdCNC For This Useful Post:
19-02-2013 #3
Hi Adam,
Just sent you an email.
Dave
RFQ: Dublin, IRL Manual milling & lathe work required
By 250rri in forum Projects, Jobs & RequestsReplies: 0Last Post: 30-01-2014, 01:07 PM -
RFQ: Some simple PAID precise Aluminium CNC work required completing? ANYone?
By justice86 in forum Projects, Jobs & RequestsReplies: 1Last Post: 03-12-2013, 08:12 PM -
RFQ: milling & turning service offered
By millerfanuc in forum Projects, Jobs & RequestsReplies: 0Last Post: 09-05-2013, 12:45 AM -
WANTED: Need a tiny bit of work done on lathe
By Tenson in forum Items WantedReplies: 4Last Post: 28-02-2013, 12:22 AM -
WANTED: Wanted: Small Metal Work Milling Machine
By 07trb in forum Items WantedReplies: 0Last Post: 04-03-2011, 06:58 PM
