14-02-2013 #1
Hello
Thank you for entering inmy post
I will be veryappreciative if you may have a look at this program I made
I did invent myself thisprogram with this drawing: (see attachments)
I didn't want to use thelatest cycles that iTNC530 offer as I am quite sure I will not havethis version but some older-ones in the company where I will have myjob trial
so that's why I did inventthat way to make the 15 holes in the center and I used polarcoordinates to make those 12 m6 holes on that circumference
I ask you to payparticular attention on the parameters I used to make thatrectangular pocket about:
allowance for side
allowance for floor
tool path overlap
plunging depth
At the end I did put acountersink to clean all the bevels that the mill leaves
Any other suggestionaccording it will be very appreciative
Thank you in advance foryour help
16-02-2013 #2
On the die drawing the program is not quite correct. After the Cycle Definitions you must use Cycle call not Call label. Also the M6 command (Tool Change) should go after the Tool Define.
16-02-2013 #3
Is there anybody else seriously using VB to program the G code they need?
By cncgcg in forum Programmers CornerReplies: 12Last Post: 16-11-2015, 10:04 PM -
How do I program my TECO VFD? Help!!
By ArdenHTF in forum General DiscussionReplies: 10Last Post: 08-07-2011, 12:23 PM -
RFQ: Write a program for me - Steel Dies
By p4tvw in forum Projects, Jobs & RequestsReplies: 8Last Post: 29-05-2010, 11:55 PM -
Free CADCAM program
By Smiler in forum Computer SoftwareReplies: 3Last Post: 12-04-2009, 05:07 PM
