    As my CNC machine is not yet finished (or even 100% designed!) I require the following...
    I am looking for the following part to be machined out of aluminium (Qty 2, T6 or similar). The counterbores may cause an issue (thin wall between counterbore and 6mm diameter hole next to it) but I can afford not to have them if they are not machinable. See image below.
    I am also looking for some lathe work where I require some small plastic spur gears to have the bore increased. There may be issues with how the spur is held in the chuck but I am hoping it is possible! Again, image below :)
    Obviously willing to pay the going rate.
ID:	8240Click image for larger version.
Name:	Spur Gear Modification.png
    Cheers,
    Dave
  2. I Can do them for you no problem, Drop me an email to sales (at) protocnc.co.uk
    Regards
    Adam
  3. The Following User Says Thank You to AdCNC For This Useful Post:
    Hi Adam,
    Just sent you an email.
    Dave
  1. RFQ: Dublin, IRL Manual milling & lathe work required
    By 250rri in forum Projects, Jobs & Requests
    Last Post: 30-01-2014, 01:07 PM
  2. RFQ: Some simple PAID precise Aluminium CNC work required completing? ANYone?
    By justice86 in forum Projects, Jobs & Requests
    Last Post: 03-12-2013, 08:12 PM
  3. RFQ: milling & turning service offered
    By millerfanuc in forum Projects, Jobs & Requests
    Last Post: 09-05-2013, 12:45 AM
  4. WANTED: Need a tiny bit of work done on lathe
    By Tenson in forum Items Wanted
    Last Post: 28-02-2013, 12:22 AM
  5. WANTED: Wanted: Small Metal Work Milling Machine
    By 07trb in forum Items Wanted
    Last Post: 04-03-2011, 06:58 PM
