Thread: Z axis trouble
22-02-2013 #2
Does the motor stall when you try to move the Z-axis up, or does it just move the Z-axis down regardless of whether you command it to go up or down? If it's the latter then there's most likely a problem with the direction signal on the Z stepper driver, so check that. You could also try plugging the Z motor into a different axis to determine if the problem lies with the Z-driver, or the motor.
5-axis Breakout Includes Hand-Held Control Port & 3,4,5-axis Postion-Display Port
By LoveLearn in forum General ElectronicsReplies: 12Last Post: 25-05-2013, 12:41 AM -
Am I asking for trouble with this? (manual milling?)
By TonyD in forum Metal Finishing TechniquesReplies: 9Last Post: 14-02-2013, 09:15 AM -
NEW MEMBER: Goal - Enable 3-Axis CNC Bed Mill to Perform 5-Axis Milling
By LoveLearn in forum New Member IntroductionsReplies: 2Last Post: 25-01-2012, 08:46 PM -
Precision metal processing (3 axis, 5 axis, 7 axis) OEM
By 7AxisCNC in forum Manufacturer NewsReplies: 0Last Post: 17-05-2011, 02:04 PM -
NEW MEMBER: now the trouble starts
By windows20 in forum New Member IntroductionsReplies: 24Last Post: 02-09-2010, 05:22 PM
