23-02-2013 #1
I'm just in the middle of building a 4x4 CNC router table to carve blocks of urethane foam.
The CNC bed and the x axis has lots of travel to accommodate thick blocks up to 500mm although its likely it'll not be cutting anything like that, more like 150mm.
The 3D forms i'm working with have quite deep profiles and change height, ie step up and down and in order to get to these I presume need longer shank bits than normal. They are also organic in shape so mega precision or high accuracy is not a a top priority. I do however require the carved shapes to have medium to smooth surface after router. Each router job is approx 500mm x 500mm x 120mm in finished volume.
I currently have a kress 6990 with 3-8mm collets. I can upgrade but at present thats what I have.
I'm a beginner to CNC and I want to know what combination of tooling bits i need to use to for the job outlined:
A: take away bulk material
B: Create an organic detailed surface.
Any advice, thoughts or links would be very much appreciated
kress any good?
By totally useless in forum Kress Milling MotorsReplies: 19Last Post: 16-02-2015, 12:19 AM -
VMC Tooling Advice Needed!
By cncJim in forum Milling Machines, Builds & ConversionsReplies: 16Last Post: 03-09-2014, 09:17 AM -
SOLD: Kress FM-6990E
By NB70 in forum Items On eBay UKReplies: 0Last Post: 10-06-2014, 04:56 PM -
Kress ATC
By Ricardoco in forum Kress Milling MotorsReplies: 13Last Post: 23-09-2012, 12:00 PM -
Tooling Up advice
By Mad Professor in forum Tool & Tooling TechnologyReplies: 4Last Post: 22-08-2012, 02:29 PM
