23-02-2013 #2
I'm working with upto 100mm thick modelling board and you'll find the kress limiting for long bit choices required to reach the depth your looking at. Really you need 12mm+ shanks for the longer cutters. I use 160mm long cutters with 14mm x 100mm flutes and a 12mm shank. Be warned that these are expensive for carbide although you can pick up HSS for a lot less.
If it were me I'd swap the kress for something that will take at least an ER20 collet like 2.2kw chinese spindle.
kress any good?
By totally useless in forum Kress Milling MotorsReplies: 19Last Post: 16-02-2015, 12:19 AM -
VMC Tooling Advice Needed!
By cncJim in forum Milling Machines, Builds & ConversionsReplies: 16Last Post: 03-09-2014, 09:17 AM -
SOLD: Kress FM-6990E
By NB70 in forum Items On eBay UKReplies: 0Last Post: 10-06-2014, 04:56 PM -
Kress ATC
By Ricardoco in forum Kress Milling MotorsReplies: 13Last Post: 23-09-2012, 12:00 PM -
Tooling Up advice
By Mad Professor in forum Tool & Tooling TechnologyReplies: 4Last Post: 22-08-2012, 02:29 PM
