Thread: Machine Problem - Rockcliff
18-02-2009 #21
18-02-2009 #22
19-02-2009 #23
19-02-2009 #24
Robin,
Quite right - uphill cutting is against the rotation of the cutter, downhill, with the rotation of the cutter. So, for internal, downhill cuts this would be CCW and external cuts would be CW. 'Uphill' and 'downhill' milling are synonymous with 'climb' and 'conventional' milling. Some materials are better cut one way rather than the other. Most good CAM software gives you the option of either.
Ramping, on the other hand, has a number of meanings. In terms of actual cutting it can mean the angle at which the tool approaches the work in the Z axis i.e. it enters the material along a slope. Ramping can also be used to express the rate at which a spindle gets up to speed.
Isn't CNC and the English language wonderful????
MikeLast edited by Mike F; 19-02-2009 at 11:16 AM. Reason: Mistake - Robin was right - brain fade
19-02-2009 #25
Ramping can also be very useful for letting a cutter designed only for side cutting to do a plunge cut.
JeffNothing is foolproof......to a sufficiently talented fool!
Boxford 125 TCL Searching for machine problem
By dragon in forum Boxford LathesReplies: 1Last Post: 28-12-2014, 09:27 PM -
Location of machine problem
By Eugene in forum Computer SoftwareReplies: 2Last Post: 27-01-2011, 07:00 AM -
Machine problem. Heiz. Blew up on me !
By xchipx in forum Heiz CNC RoutersReplies: 2Last Post: 03-04-2009, 01:08 PM -
Machine problem with softlimits mach3 & Estop
By Steve-m in forum Artsoft Mach (3 & 4)Replies: 9Last Post: 12-01-2009, 05:38 PM -
NEW MEMBER: Rockcliff
By Rockcliff in forum New Member IntroductionsReplies: 3Last Post: 05-08-2007, 02:32 AM
