Thread: Machine Problem - Rockcliff
Lee,
The discrepancy and the pauses will be the backlash compensation. On a change of direction of an axis, Mach pauses the cut while the backlash is taken out. I am sure there is somewhere within Mach that lets you change the speed of the update but I'm not sure where it is as I do not need backlash comp on my machine - apologies, I don't mean to gloat :)
Mike
18-02-2009 #2What are you using for the spindle motor? If you intend to use anything heavier than a Dremel, then you really need to consider using larger diameter rails. The flexing in a 1/2" (12.7mm) rail is too great for anything other than cutting polystyrene; seriously. Nick at RockCliff stresses that in his forums that his initial designs used 1/2" and he has since up graded to 5/8" or 16mm. It is amazing how much more rigidity that extra 3mm provides.I used 12 1/2mm round rail and mdf for the build and because of this the machine is weak? Fragile? I don’t know what the best description is.
As for MDF -- if you used the 19mm as spec'ed, you will have ample strength for cutting even light gauge metal sheet.
I have been using a B&Q 1020W £20 router with a modified base -- it is heavy at 2kg, and with the Z motor at 1.85 Nm I can't drive it quicker than 300 mm/min or it stalls out. I'm using motor driver modules from http://www.jafmotion.co.uk/motordrives.htm that I think need to be used with caution.
The other thing to ask is do you need backlash compensation?
To prove it maybe cut a square with your 3mm cutter and repeat it many times. If the track is still only 3mm after 10 or 15 repeats, then you do not need backlash compensation.
I need to get a new X/Z interface plate made in Al with bearing blocks in Al that won't shake loose in time.
My machine was built using 19mm MDF as per the plans; 16mm and 5/8" guide rails (redeemed from plotters and ebay), and Oil-Lite sleeve bearings; Lead screw 10 x 1.5 mm standard threaded bar from B&Q. FL57STH76-2808B motors from http://www.motioncontrolproducts.com/nema23.html.
cheersTemplecorran
Where the Light was kept during the Dark Ages
Boxford 125 TCL Searching for machine problem
By dragon in forum Boxford LathesReplies: 1Last Post: 28-12-2014, 09:27 PM -
Location of machine problem
By Eugene in forum Computer SoftwareReplies: 2Last Post: 27-01-2011, 07:00 AM -
Machine problem. Heiz. Blew up on me !
By xchipx in forum Heiz CNC RoutersReplies: 2Last Post: 03-04-2009, 01:08 PM -
Machine problem with softlimits mach3 & Estop
By Steve-m in forum Artsoft Mach (3 & 4)Replies: 9Last Post: 12-01-2009, 05:38 PM -
NEW MEMBER: Rockcliff
By Rockcliff in forum New Member IntroductionsReplies: 3Last Post: 05-08-2007, 02:32 AM
