Normally I'd say make the Z-axis as short as possible, but if you really want a B/C axis head then you do need a long Z-axis. What drive mechanism are you planning on using for the B/C axes? Either way the gantry needs to be *much* stronger. Look at some of the past build logs on this forum to get ideas.
You should run the motors on about 70V - drivers are around £35 each from China, which will be far superior to the TB6xxx ones.
Z is fine with RM1605, Y is best with RM1610. No point using a rotating nut on Y or Z as it's not near the critical speed of the screw.
With X you're on the borderline for using RM1610. If your maximum travel is 1350mm, then you should be able to use a 1450mm screw quite comfortably which would be fine with RM1610 without the rotating nut. If you want it to be a bit longer, then the rotating nut with RM1610 will work very well. Putting both pulleys on to get 2:1 and 1:2 is a nice idea, the problem is it doubles (ish) the moment of inertia, which will greatly affect the acceleration you get. For that reason I would stick with just the one pulley and make the shaft as short/lightweight as you can.
The Following User Says Thank You to Jonathan For This Useful Post:
LIMAC knife cutting machine and plasma machine, cnc router latest video
By therouterlady in forum Manufacturer NewsReplies: 0Last Post: 18-09-2013, 05:28 AM -
My first 700 x 500 x 300 Mill/Router machine
By Lovre in forum Gantry/Router Machines & BuildingReplies: 16Last Post: 09-02-2013, 09:28 PM -
Dm 6090 cnc router machine from china
By troyboy1 in forum Milling Machines, Builds & ConversionsReplies: 1Last Post: 04-12-2012, 11:19 PM -
Need help setting up a CNC router machine please
By 1albobs in forum Gantry/Router Machines & BuildingReplies: 4Last Post: 27-02-2012, 06:16 PM -
CNC Router Machine?????
By anamsey in forum General DiscussionReplies: 1Last Post: 09-07-2011, 08:01 AM
