Thread: 100 paper gaskets required
24-02-2013 #1
Hi, I have a request for 100 gaskets to be cut from gasket paper no more than 0.5mm thick.
I have not created a drawing yet, but to give you an idea: It will be oval shaped approx 50mm x 35mm, 25mm hole in centre, with a 6mm hole either side of the centre hole. I hope this makes sense. I thought this might be ideal for someone with a homemade router etc.....
I must stress that this needs to be cheap and more similar work will follow.
24-02-2013 #2
I don't know if "milling" gasket paper is possible? I guess the paper would have to be placed on a vacuum table or firmly fixed with masking tape which may damage the paper when removed. As far as I know, gaskets are normally cut with a press tool, which could be made on a CNC milling machine. Perhaps someone here has some kind of CNC shears or scissors? Or maybe a laser cutter?
I'm afraid that I cannot offer a solution, but it will be interesting to see what other members suggest...Last edited by birchy; 24-02-2013 at 11:17 PM.
24-02-2013 #3
Laser it. The world is full of people with 40W - 80W desktop lasers looking for something to do.
24-02-2013 #4
mmmm...... What about a mill with a drag knife or maybe a vinyl plotter. Dont know how deep the latter would cut or if it would need a backing sheet.
24-02-2013 #5
Robin, would'nt a laser burn the edges?
24-02-2013 #6
Sent you a PM, check your messages at the top of the screen.
John S -
25-02-2013 #7
WANTED: Off-cut required.
By Wal in forum Items WantedReplies: 8Last Post: 14-12-2015, 11:09 PM -
RFQ: Parts Required
By PaulW in forum Projects, Jobs & RequestsReplies: 0Last Post: 15-04-2014, 02:44 PM -
FOR SALE: Just seen Myford Lathe for sale in local paper ...
By Spedley in forum Items For SaleReplies: 5Last Post: 01-08-2013, 11:32 PM -
Tooling for Cardboard & Paper
By bigstu67 in forum Tool & Tooling TechnologyReplies: 1Last Post: 23-11-2012, 04:44 PM -
NEW MEMBER: Help required
By Vespa Mad in forum New Member IntroductionsReplies: 1Last Post: 24-06-2009, 02:06 PM
