Hi !
The pipes I got with my kit were PVC 6mm. However, I do not recommend those. Personally I find PVC too rigid and prefer much more plastic hose used in gas powered remote control airplanes. If there is a store close to your house that sell that kind of planes, just get it there. It's quite cheap. Otherwise you can order it online :)
12-09-2015 #2
12-09-2015 #3
Weird :/ Mine is different. It's made of plastic, exactly like the one on this kit:
http://www.aliexpress.com/item/CNC-S...444_5,201409_1
Though I have to admit it was quite hard to fit the pipe that came with the spindle. The coupler I have has the same size as the one on the spindle.Last edited by eurikain; 12-09-2015 at 10:00 PM.
13-09-2015 #4
Many of you have the same setup. Where do you find the connector?
Gabi
13-09-2015 #5
Not sure what your asking here . ? . . . The pump in the picture doesn't need or use a connector it's got a Barb so you just push the pipe on and clip it.!
If your wanting the Barb Fitting that screws into the pump then try these people.
http://airaccessories.fluidfittingss...s/0033000a0007
13-09-2015 #6
Hi JazzCNC,
The photo is for reference only. My pump came with a bigger plastic connector. I will have a look on that site.
Still maybe know where I can buy the right one. I bought the 3/4" barb and doesn't fit, it is a hair big...
Thx
Gabi
26-12-2015 #7
Got some Noob questions. Thanks for any help.
1. Can anyone confirm if its safe to power up the VFD without the spindle connected for setting the parameters at the beginning ?
2. I have already purchased 3 core foil shielded Belden Cable for my spindle.
http://www.ebay.co.uk/itm/111817521022
Is this ok ?
I just read i was supposed to use 4 core CY Cable.
3. Do i have to earth the spindle at the spindle end by removing the top and making a ground point and connect to pin 4?
E.g. Should I have 4 core cable as well as the shielding ?
Martin
Chinese Spindles
By Ricardoco in forum Generic Chinese SpindlesReplies: 123Last Post: 05-12-2016, 12:16 AM -
Info on Chinese suppliers, their reliability and reputation
By Want2build1 in forum Marketplace DiscussionReplies: 38Last Post: 07-12-2013, 09:37 PM -
NEW MEMBER: Seeking advice on a CNC setup for (one off) machining carbon fiber plate
By Tomcat in forum New Member IntroductionsReplies: 0Last Post: 03-03-2013, 01:43 PM -
Chinese spindles
By Colin Barron in forum Marketplace DiscussionReplies: 15Last Post: 23-08-2011, 08:58 PM -
Chinese 1.5kw Spindles
By jcb121 in forum Generic Chinese SpindlesReplies: 12Last Post: 28-07-2011, 06:20 PM
