26-03-2013 #11
It's clear that we have good evidence to expect to receive a good spindle from Chai, but to me that's not reason enough to spend at least 36 extra on one. The only part I've heard of having problems is the spindle bearings, in particular using relatively cheap Chinese bearings and installing them incorrectly.
Lower quality bearings:
- We don't know if Chai uses 'good' bearings or not.
- They're likely to not last as long as high grade bearings, but apart from that I doubt you will notice a difference. They may run at a very slightly higher temperature, or have marginally lower run-out, but for the vast majority of people that is a negligible error. If you really need very low runout, then spend the extra 150-200 ish and get a better quality spindle from Aliexpress.com as that will be far better than the former, even if you get lucky.
Incorrect bearing installation:
- This is clearly bad, but if you notice it before it's too late then it's not difficult to change the bearings round. These spindles are surprisingly easy to dismantle.
- I can only find evidence of a spindle with 3 bearings being assembled incorrectly. Therefore if you get a 4 bearing spindle, which is a good idea anyway, then we can expect it to be assembled correctly. The 4 bearing spindles use 4 angular contact bearings, with the front pair both one way and the top pair the opposite way, placing the shaft in tension.
So overall, yes spending the extra money does give you peace of mind, but if you compare that to the probability of getting a bad one from other sellers it's surely worth 'risking' it. Also you can get the spindles a little cheaper than the standard eBay price if you use aliexpress and perhaps more importantly their payment system is such that the seller only gets your money when the item has arrived and you say it's good. That's pretty good leverage when trying to get a bad product replaced.
Remember to search worldwide - if you tick UK only the prices are silly.
Don't - you can't use very low speeds with the air cooled ones, otherwise they overheat. They're also going to be much noisier, which will add to the total noise when cutting. Also what's to suggest the bearings in an air cooled one will be any better?
I've never seen a warranty seal on one, but equally I wouldn't recommend dismantling one just for kicks...since knowing which bearings you have doesn't really change how you use it.Last edited by Jonathan; 26-03-2013 at 01:51 AM.
Chinese Spindles
By Ricardoco in forum Generic Chinese SpindlesReplies: 123Last Post: 05-12-2016, 12:16 AM -
Info on Chinese suppliers, their reliability and reputation
By Want2build1 in forum Marketplace DiscussionReplies: 38Last Post: 07-12-2013, 09:37 PM -
NEW MEMBER: Seeking advice on a CNC setup for (one off) machining carbon fiber plate
By Tomcat in forum New Member IntroductionsReplies: 0Last Post: 03-03-2013, 01:43 PM -
Chinese spindles
By Colin Barron in forum Marketplace DiscussionReplies: 15Last Post: 23-08-2011, 08:58 PM -
Chinese 1.5kw Spindles
By jcb121 in forum Generic Chinese SpindlesReplies: 12Last Post: 28-07-2011, 06:20 PM
