02-04-2013 #1Always bear in mind that your own resolution to succeed is more important than any other - Abe Lincoln
02-04-2013 #2
I was indeed, my BoB with PWM is in need of repair so I bought a cheap ebay job that is actually pretty good only no PWM. So I will use the RS485 converter(I actually had one for some reason, past project I guess) and see how I get on. Next is finding some springs to counter balance my Z axis :)
03-04-2013 #3
Can the UVW go in any order as long as it spins correctly or do they need to go to the correct pins? I have the earth from the spindle going to E is that OK? Do I need to use all 3 wires from the mains or just the live/neutral? I'm close to testing it out now :)
03-04-2013 #4
03-04-2013 #5
for those saying the cost is massive at the minute, i'm still finding 2.2kw spindles with vfd's for £252
80 diameter 2.2kw WATER-COOLED SPINDLE MOTOR AND INVERTER VFD DRIVE four bearing | eBay
yes there are some more expensive, but theres plenty in the £252 range as well, admittedly they are all from solar.jeanLast edited by wilfy; 03-04-2013 at 08:00 PM.
03-04-2013 #6
I've connected the shielding to eartch at the VFD, I assume its the correct way?
Also, would these VFD settings work with the 1.5kw spindle, I cant find the bit of paper that came with it :)
Thanks, Phil
03-04-2013 #7
Managed to sort it, fired it up and its sweet. One thing thats bothering me is at 24k theres almost like a rattle inside that sounds like a bad bearing but drop a few thousand rpm and it vanishes.
Good points are when it was running there was 0 vibrations on the kitchen counter and it sounds good although its going to be a while before I get used to the different sounds at different ranges, I'm used to it just getting loader :D
Cheers, Phil
Chinese Spindles
By Ricardoco in forum Generic Chinese SpindlesReplies: 123Last Post: 05-12-2016, 12:16 AM -
Info on Chinese suppliers, their reliability and reputation
By Want2build1 in forum Marketplace DiscussionReplies: 38Last Post: 07-12-2013, 09:37 PM -
NEW MEMBER: Seeking advice on a CNC setup for (one off) machining carbon fiber plate
By Tomcat in forum New Member IntroductionsReplies: 0Last Post: 03-03-2013, 01:43 PM -
Chinese spindles
By Colin Barron in forum Marketplace DiscussionReplies: 15Last Post: 23-08-2011, 08:58 PM -
Chinese 1.5kw Spindles
By jcb121 in forum Generic Chinese SpindlesReplies: 12Last Post: 28-07-2011, 06:20 PM
