Page 15 of 23 FirstFirst ... 51314151617 ... LastLast
  1. #141
    Lives in Marple Stockport, United Kingdom. Last Activity: 19 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,346. Received thanks 618 times, giving thanks to others 87 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Just to clarify, this is true for the shield but you should ideally also earth the body of the spindle, not relying on earthing through the machine frame as the bearings are not predictable.
    Yes I agree with that also it is a good idea to put some form of cable restraint on the spindle so as to stop the connections breaking in the plug and causing the VFD to fail.
  2. #142
    In my Belden wire it has 3 insulated cores, an. Outer foil shield and a non insulated wire together with the shield. So are you saying connect the shield and non insulated wire to the spindle body at one end and to ground at the vfd end?
  3. #143
    Quote Originally Posted by mturneruk View Post
    Yes exactly that. You can solder or crimp .a short piece of wire and then put heat shrink on
  4. #144
    Clive, can you post a picture pleaaaaaase ?
  5. #145
    Quote Originally Posted by eurikain View Post
    Sorry I don't have a picture. I use CY 4 core. Can you say what you are not understanding and I will try and explain better.
  6. #146
    I was talking about the part where you solder the cable to the shield. I'd be curious to see how you do it.
  7. #147
    Ok It depends on how course the weave is on the shield. If it is course you can use a pointed object and tease the cores out through it then you have a strand of shield left to solder to.
    If it is tight weave then you have to cut it and then twist it to a strand with the ground drain wire and then solder an earth wire to that . use heat shrink to make it neat. In this pic it is the blue wire with green/yellow sleeve to identify it as earth star point. but the same can be done for the spindle.
  8. #148
    Thanks for the image :) I see what you mean.
    Now, when you open the spindle cap, you just solder a wire from pin 4 to the spindle shield ? I mean, literally to the metallic shield right under the cap ?
  9. #149
    Ok it depends if you have 3 or 4 pins on your spindle socket if you have 4 one of them may not be connected to anything. I took the end cap off and soldered a wire to the vacant pin and put a longer screw in the socket and attached the wire to a ring connector which then fitted over the longer screw and fastened it with a nut inside. Then you can use that pin as the earth in the plug. If you only have 3 pins in the socket then you have to attach the earth to the spindle or clamp.
  10. #150
    Perfect description, thanks Clive, you're an ace :)
  1. Chinese Spindles
    By Ricardoco in forum Generic Chinese Spindles
    Last Post: 05-12-2016, 12:16 AM
  2. Info on Chinese suppliers, their reliability and reputation
    By Want2build1 in forum Marketplace Discussion
    Last Post: 07-12-2013, 09:37 PM
  3. NEW MEMBER: Seeking advice on a CNC setup for (one off) machining carbon fiber plate
    By Tomcat in forum New Member Introductions
    Last Post: 03-03-2013, 01:43 PM
  4. Chinese spindles
    By Colin Barron in forum Marketplace Discussion
    Last Post: 23-08-2011, 08:58 PM
  5. Chinese 1.5kw Spindles
    By jcb121 in forum Generic Chinese Spindles
    Last Post: 28-07-2011, 06:20 PM
