Page 21 of 23 FirstFirst ... 111920212223 LastLast
  1. #201
    >because pins touched due to poor soldering
    Hehe. Dean, the soldering was good, it's just that there was too much of good soldering..! ;)
    Wal.
    The old maxim that "the bigger the blob, the better the job" was NEVER good soldering
    Scrupulous cleanliness is the key, a one molecule thick layer of grease from your fingers is enough to ruin what could have been a good joint.
    Kit
    PS Like, wow man! far out! That was a seriously good joint, dude.
  2. #202
    Advice of the day: don't wait 3 months before testing your fresh received toy...
    https://www.youtube.com/watch?v=2xUZyw0eeSg
    https://www.youtube.com/watch?v=pfNIaMwcSyo
    So disappointed.
    Best regards
  3. #203
    Quote Originally Posted by aprex View Post
    So disappointed.
    Best regards
    Have you set the parameters in the VFD
  4. #204
    Yes, even by hand you can hear a discrète grinding noise.
  5. #205
    Think I might be buying another from the same place and sending the old one back for a refund
  6. #206
    oooh you fiend!
  7. #207
    No mercy when you read their answers to my problem; warrant y or exchange/refund, they're deaf...
    I hope return address is the same as sending address (deuchland). Shipping cost could be a pita
  8. #208
    So disappointed.
    Best regards
    This advice goes for anything related to CNC, esp electronics. This is the biggest mistake new builders make next to buying stepper kits.
    Only buy when required because not only do you get a warranty when needed but electronics change fast these days and it's sod's law when you fit it you are already behind the times in technology.
  9. #209
    Very sorry to read about your problems.
    Clearly the ideal solution is replacement by the supplier or manufacturer. If you bought it within the EU you should have some protection (unlike our pommie friends since Friday ) and it may be worth checking if your method of purchase offers any protection or insurance.
    If they refuse to help you then there may be people on this site with experience of dismantling and repairing these spindles who can advise you. It sounds like a bearing problem which is something you may be able to repair yourself with the right help.
  10. #210
    Thanks a lot Kitwn, you're right, speaking with my seller makes me understand than it will be a DIY story...
    Well, little humor story just for fun:
    Just finished my CNC and started the spindle; this one makes a very bad bearing noise. I can upload a video for you. Very disappointed...
    Best regards
    31/01 07:15
    Dear friend,
    don't worry,our engineer tell us ,that is no problem, and he said: when the spindle bearing in the high-speed operation, the start state is unstable, may be possible to produce a variety of noise, the noise is the product in the transport process in the accumulation of grease caused by the side,until the grease dispersed after the spindle no such, you can use it ,
    Kind regards
    Cher ami,
    Ne vous inquiétez pas, notre ingénieur nous dit, ce n'est pas un problème, et il a dit: lorsque le roulement de la broche dans l'opération à grande vitesse, l'état de démarrage est instable, peut être possible de produire une variété de bruit, Le bruit est le produit dans le processus de transport dans l'accumulation de graisse causée par le côté, jusqu'à ce que la graisse se dissipe après la broche, vous pouvez l'utiliser,
    Merci
    Cordialement
    31/01 08:03
    Dear friend,
    I don't think, it's a grinding noise, when you turn the spindle by hand you can hear a grinding noise. Even when you run it at 6000rpm. Do you have a mail address to upload you a video?
    Thanks by advance
    31/01 09:21
    I'll upload the video on youtube and send you the link later.Best regards.
    31/01 09:29
    https://youtu.be/2xUZyw0eeSg
    01/02 06:17
    Dear friend,
    many thanks for your buying,
    pls follow this information :VFD input R,S,T port,any two ports connecting mains 220 V/AC and on the spindle motor connerter 1,2,3, connection to on the inverter :U,V,W, the mean is 1=U,2=V,3=W, 4 is blank, can't connection to GND, The minimum speed of the spindle should not be less than 9000rpm .and the VFD don't need any setting, that will be to work,
    if you need any help,pls let me know,
    Kind regards
    Cher ami,
    Merci beaucoup pour votre achat,
    Veuillez suivre ces informations: entrée VFD R, S, port T, tous les deux ports connectant le secteur 220 V/AC et sur le connecteur de moteur de broche 1,2, 3, connexion sur l'onduleur: u, V, W, la moyenne est 1 = U, 2 = V, 3 = W, 4 est vide, ne peut pas se connecter à GND, la vitesse minimale de la broche ne devrait pas être inférieure à 9000 tr/min. Et le VFD n'a pas besoin de réglage, ce sera pour fonctionner,
    Si vous avez besoin d'aide, veuillez me le faire savoir,
    Cordialement
    pls notice The minimum speed of the spindle should not be less than 9000rpm
    Veuillez noter que la vitesse minimale de la broche ne doit pas être inférieure à 9000 tr/min
    01/02 10:26
    Dear friend, https://youtu.be/pfNIaMwcSyo Just checked of course, my wiring is ok. Each minute of running becomes worst and worst. Even the speed is not stable, a faulty bearing I think.It's clear for me, this one is defective...
    Best regards.
    01/02 15:24
    This is damaged bearings spindle motor, pls check it : https://drive.google.com/file/d/1G7l...ew?usp=sharing
    Ceci est endommagé moteur de broche de roulements, veuillez le vérifier: https://drive.google.com/file/d/1G7l...ew?usp=sharing
    01/02 16:25
    I never used it, can't I have an exchange?
    02/02 05:58
    we will send video to our engineer and help you solve the problem
    Nous enverrons une vidéo à notre ingénieur et vous aiderons à résoudre le problème
    Hier 09:52
    Dear P....e, Confirmed through numerous forums as cnczone and mycncuk; is there any warranty?
    Best regards
    02:50
    The spindle motor no any problem, i don't understand, , what you need warranty ?
    Le moteur de broche pas de problème, je ne comprends pas,, que vous avez besoin de garantie?
    07:32
    You just said : This is damaged bearings spindle motor, pls check it : https://drive.google.com/file/d/1G7l...ew?usp=sharing
    Isn't it a failure?!
    10:11
    but you spindle motor problem don't same as this spindle motor
    Mais vous problème de moteur de broche ne sont pas les mêmes que ce moteur de broche
    Alibaba Translation
    10:39
    All apologies. This is my spindle:
    so, What is my problem?
    you don't have any problem of your motor, you can use it
    Vous n'avez pas de problème de votre moteur, vous pouvez l'utiliser
    !!!!!!! It spins, so it works!!!!
There are currently 22 users browsing this thread. (0 members and 22 guests)
  1. Chinese Spindles
    By Ricardoco in forum Generic Chinese Spindles
    Last Post: 05-12-2016, 12:16 AM
  2. Info on Chinese suppliers, their reliability and reputation
    By Want2build1 in forum Marketplace Discussion
    Last Post: 07-12-2013, 09:37 PM
  3. NEW MEMBER: Seeking advice on a CNC setup for (one off) machining carbon fiber plate
    By Tomcat in forum New Member Introductions
    Last Post: 03-03-2013, 01:43 PM
  4. Chinese spindles
    By Colin Barron in forum Marketplace Discussion
    Last Post: 23-08-2011, 08:58 PM
  5. Chinese 1.5kw Spindles
    By jcb121 in forum Generic Chinese Spindles
    Last Post: 28-07-2011, 06:20 PM
