Don't forget you also have to pay the electric bill, needlessly burning an extra 800watts adds up...
I'm not sure exactly where the sweet spot is with cnc machines, perhaps someone that has a few years experience has being moitoring their leccy bill but in school/college IT centres when you do the figures the electric bill works out as being more expensive over the lifetime of the machine than the capital cost of the computers.
27-03-2013 #2
They've tripled the price beacuse........
"We are sorry that because this item is now out of stock in UK, so we rise the price."
Will the lower price return when you have stocks in the UK?
"Yes, once this item can be available in UK, we will lower the price as before."Last edited by r0bsk1; 27-03-2013 at 12:11 PM.
The Following User Says Thank You to r0bsk1 For This Useful Post:
27-03-2013 #3
I asked solar.jean if all his 2.2kw spindles are the same model/making and he confirmed "yes,that's right,all is same mode and same factory" and he added "we sell the products as total amount of USD374 (price+freight)".
No matter if you bid for the Japanese bearings or the German ones you will get the same product from him.
Possible to be the same seller from Aliexpress with the lowest price (note the Japanese and German bearings mentioned in the same listing).
Chai sells spindles manufactured by Jiesite and Jean the ones made by Huajiang. Both located in the Changzhou city. In my opinion both companies produces the "cheapest" Chinese spindles Jiesite is the only spindle manufacturer/trader on Alibaba who does not provide information about the bearings used. Huajiang has a made-in-china account where the P4 bearing grade is listed only for the 3 and 4.5kw models.
Jiesite seems to be a smaller and younger company with better quality control compared to Huajiang. They also have some interesting tips for spindle use. Here follows the most interesting one:
None of the Chinese manufacturers claim to use import bearings.During storage and transport of the spindle, the status of high-speed grease inside the bearing will change. The user shall run it at a low speed first by starting from the lowest speed of the spindle for 30 minutes and then 20 minutes for every 3000 rounds; otherwise there will have abnormal sound, noise, heat and other phenomena, which will affect the bearing life if the spindle is started directly at a high speed. During long term storage, the spindle shall run (at low speed) for 15~30 minutes once a week at least.Last edited by paulus.v; 27-03-2013 at 05:23 PM.
27-03-2013 #4
27-03-2013 #5
I was just about to buy one too so ive also asked for an ETA on UK stock
02-04-2013 #6
Is it possible to have Mach control the speed of the spindle, I've not used the new spindle yet so I'm not sure if its possible :)
02-04-2013 #7Always bear in mind that your own resolution to succeed is more important than any other - Abe Lincoln
02-04-2013 #8
Cheers, will go look now. I cant imagine not sitting around the machine waiting to change speed or turn the spindle on/off. Should be fun! :)
11-05-2013 #9
Hi All,
Finally got my spindle and vfd from here []WATER COOLE MOTOR SPINDLE 2.2KW VFD MATCHING INVERTER ENGRAVING GRINDING l7 | eBay ("Happykissoul") for £221 including carriage. Price has gone up since I ordered on the 6th May. Turned up this afternoon (Saturday 11th May). Well wrapped, so hopefully courier proof - (Did anyone see the documentary on BBC!). Don't know how many bearings it has but it is much heavier than I thought it would be. Hope the gantry is up to it! VFD is the usual Huanyang one and hope the modbus works in it. Also supplied with 4 collets 4mm,6mm,8mm,12mm, 1/2" and spindle connector plug. Will try it out this week before giving feed back on ebay and will post some pictures here.
Thanks guys for this thread and all the help with the CNC Mill design. Building starts soon
Regards
Mike
12-05-2013 #10
Slightly off topic but does anyone know where to get replacement water nipples for these spindles?
iv been to my local pneumatic/hydraulic suppliers and they couldnt help.
any ideas ?
Chinese Spindles
By Ricardoco in forum Generic Chinese SpindlesReplies: 123Last Post: 05-12-2016, 12:16 AM -
Info on Chinese suppliers, their reliability and reputation
By Want2build1 in forum Marketplace DiscussionReplies: 38Last Post: 07-12-2013, 09:37 PM -
NEW MEMBER: Seeking advice on a CNC setup for (one off) machining carbon fiber plate
By Tomcat in forum New Member IntroductionsReplies: 0Last Post: 03-03-2013, 01:43 PM -
Chinese spindles
By Colin Barron in forum Marketplace DiscussionReplies: 15Last Post: 23-08-2011, 08:58 PM -
Chinese 1.5kw Spindles
By jcb121 in forum Generic Chinese SpindlesReplies: 12Last Post: 28-07-2011, 06:20 PM
