    I think he is being pointed toward the usb > serial (RS485 i think) lead from PC to VFD that does the control with a plugin for mach, not tried them so couldnt comment.
    Rick
    I was indeed, my BoB with PWM is in need of repair so I bought a cheap ebay job that is actually pretty good only no PWM. So I will use the RS485 converter(I actually had one for some reason, past project I guess) and see how I get on. Next is finding some springs to counter balance my Z axis :)
    Can the UVW go in any order as long as it spins correctly or do they need to go to the correct pins? I have the earth from the spindle going to E is that OK? Do I need to use all 3 wires from the mains or just the live/neutral? I'm close to testing it out now :)
    Live and neutral go to any of RST and both earths goes to earth. UVW in any order is fine, so long as the spindle runs in the right direction.
    for those saying the cost is massive at the minute, i'm still finding 2.2kw spindles with vfd's for £252
    80 diameter 2.2kw WATER-COOLED SPINDLE MOTOR AND INVERTER VFD DRIVE four bearing | eBay
    yes there are some more expensive, but theres plenty in the £252 range as well, admittedly they are all from solar.jean
    I've connected the shielding to eartch at the VFD, I assume its the correct way?
    Also, would these VFD settings work with the 1.5kw spindle, I cant find the bit of paper that came with it :)
    Thanks, Phil
    Managed to sort it, fired it up and its sweet. One thing thats bothering me is at 24k theres almost like a rattle inside that sounds like a bad bearing but drop a few thousand rpm and it vanishes.
    Good points are when it was running there was 0 vibrations on the kitchen counter and it sounds good although its going to be a while before I get used to the different sounds at different ranges, I'm used to it just getting loader :D
    Cheers, Phil
    Phil
    Like a new car it is worth running the bearings in before loading it up at full chat.
  1. Chinese Spindles
    By Ricardoco in forum Generic Chinese Spindles
    Last Post: 05-12-2016, 12:16 AM
  2. Info on Chinese suppliers, their reliability and reputation
    By Want2build1 in forum Marketplace Discussion
    Last Post: 07-12-2013, 09:37 PM
  3. NEW MEMBER: Seeking advice on a CNC setup for (one off) machining carbon fiber plate
    By Tomcat in forum New Member Introductions
    Last Post: 03-03-2013, 01:43 PM
  4. Chinese spindles
    By Colin Barron in forum Marketplace Discussion
    Last Post: 23-08-2011, 08:58 PM
  5. Chinese 1.5kw Spindles
    By jcb121 in forum Generic Chinese Spindles
    Last Post: 28-07-2011, 06:20 PM
