FYI 2.2k spindles and vfd are back in stock in the uk. Price has dropped too.
10-04-2013 #2
Thanks r0bsk1 for posting this I will check eBay now.
Regds
Mike
12-04-2013 #3
Damn my hastiness, I bought the cheapest one from aliexpress a few days ago and it was £8 (plus £1 bank charge) more than they're now selling them in the UK on ebay. Plus the seller has dispatched it with FedEx even though I chose DHL as the courier, so now I'll get a nice admin charge from them. Oh well
I'll post again when it arrives
22-04-2013 #4
Hi guys. What do I go for a four bearing one from uk or 3 bearing one from chai?? I can't decide
Dan
25-04-2013 #5
Still looking at spindles on eBay and unsure. Had a good price off chai but with shipping takes it up a fair bit.
There's one via solar.jean which I am tempted by, is a four bearing model but only has a 3 pin connector. Is this an issue? Can an earth still be fitted - does it need one?Dan
25-04-2013 #6
You could easily change it for a 4 pin connector, or just fasten the earth cable to the spindle body via the spindle mount or tapped hole in the Z-axis, assuming they're all metal.
The 3-pin connector may imply it's an older spindle, since in the past these spindles used to exclusively use 3-pin connectors. Clearly that's just speculation though...as I've already mentioned, my spindle with 3-pin connector from solar.jean has been good and does include 4 bearings.
25-04-2013 #7
just buy it!. it'll be fine.
Chinese Spindles
By Ricardoco in forum Generic Chinese SpindlesReplies: 123Last Post: 05-12-2016, 12:16 AM -
Info on Chinese suppliers, their reliability and reputation
By Want2build1 in forum Marketplace DiscussionReplies: 38Last Post: 07-12-2013, 09:37 PM -
NEW MEMBER: Seeking advice on a CNC setup for (one off) machining carbon fiber plate
By Tomcat in forum New Member IntroductionsReplies: 0Last Post: 03-03-2013, 01:43 PM -
Chinese spindles
By Colin Barron in forum Marketplace DiscussionReplies: 15Last Post: 23-08-2011, 08:58 PM -
Chinese 1.5kw Spindles
By jcb121 in forum Generic Chinese SpindlesReplies: 12Last Post: 28-07-2011, 06:20 PM
