  1. #10
    If enough force has been applied to the spindle to push the angular contact bearings out of alignment, then the bearings are seriously damaged. I'd return it as it's clearly faulty. This isn't just a generic motor, it's a spindle which uses 'super precision' bearings, for good reason. Having dismantled one of these spindles, I can't really see how it could seize without it being permanently damaged.
    If returning is not possible, you may have to replace the bearings which is not too difficult, just expensive.
  1. Chinese Spindles
    By Ricardoco in forum Generic Chinese Spindles
    Last Post: 05-12-2016, 12:16 AM
  2. Info on Chinese suppliers, their reliability and reputation
    By Want2build1 in forum Marketplace Discussion
    Last Post: 07-12-2013, 09:37 PM
  3. NEW MEMBER: Seeking advice on a CNC setup for (one off) machining carbon fiber plate
    By Tomcat in forum New Member Introductions
    Last Post: 03-03-2013, 01:43 PM
  4. Chinese spindles
    By Colin Barron in forum Marketplace Discussion
    Last Post: 23-08-2011, 08:58 PM
  5. Chinese 1.5kw Spindles
    By jcb121 in forum Generic Chinese Spindles
    Last Post: 28-07-2011, 06:20 PM
