    Something like this Ultra Quiet Mini DC 12V 3M 240L H Brushless Motor Submersible Water Pump Hot | eBay would be fine. I was surprised just how little water was needed to keep the spindle cool. A central heating pump would be massive overkill and in my opinion (for what its worth) would possibly make the pump cavitate because of the small pipes in the system and of course the power wasted with such a pump ..Clive
    Your right! I got my pluming wrong, I thought he was asking for flood coolant, do you think that would be overkill as well ?
    Lives in Marple Stockport, United Kingdom. Last Activity: 20 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,346. Received thanks 618 times, giving thanks to others 87 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Sorry Lee I can't comment on flood cooling but I think it would be overkill also standard CH pumps use a cast prop but you can get them with a bronze one used for hot water secondary circulation but are very expensive. ..Clive
    Thanks for the pump advice,are the Chinese spindle mounts ok? I messaged someone on the forum about making a mount but not had a reply.
    Quote Originally Posted by andrewuk View Post
    Why not put a sketch with dimensions up here and see what happens.. ..Clive
  1. Chinese Spindles
    By Ricardoco in forum Generic Chinese Spindles
    Last Post: 05-12-2016, 12:16 AM
  2. Info on Chinese suppliers, their reliability and reputation
    By Want2build1 in forum Marketplace Discussion
    Last Post: 07-12-2013, 09:37 PM
  3. NEW MEMBER: Seeking advice on a CNC setup for (one off) machining carbon fiber plate
    By Tomcat in forum New Member Introductions
    Last Post: 03-03-2013, 01:43 PM
  4. Chinese spindles
    By Colin Barron in forum Marketplace Discussion
    Last Post: 23-08-2011, 08:58 PM
  5. Chinese 1.5kw Spindles
    By jcb121 in forum Generic Chinese Spindles
    Last Post: 28-07-2011, 06:20 PM
