Got some Noob questions. Thanks for any help.
1. Can anyone confirm if its safe to power up the VFD without the spindle connected for setting the parameters at the beginning ?
2. I have already purchased 3 core foil shielded Belden Cable for my spindle.
http://www.ebay.co.uk/itm/111817521022
Is this ok ?
I just read i was supposed to use 4 core CY Cable.
3. Do i have to earth the spindle at the spindle end by removing the top and making a ground point and connect to pin 4?
E.g. Should I have 4 core cable as well as the shielding ?
Martin
27-12-2015 #2
1. I believe it is ok to run the vfd without being connected BUT do not connect or disconnect with it powered up.
2. Yes it will be OK CY cable is generally used but you have already purchased it so use it.
3. It is ok to earth the shield at the VFD end only, 4 core is not a necessity ...Clive
27-12-2015 #3
27-12-2015 #4
Chinese Spindles
By Ricardoco in forum Generic Chinese SpindlesReplies: 123Last Post: 05-12-2016, 12:16 AM -
Info on Chinese suppliers, their reliability and reputation
By Want2build1 in forum Marketplace DiscussionReplies: 38Last Post: 07-12-2013, 09:37 PM -
NEW MEMBER: Seeking advice on a CNC setup for (one off) machining carbon fiber plate
By Tomcat in forum New Member IntroductionsReplies: 0Last Post: 03-03-2013, 01:43 PM -
Chinese spindles
By Colin Barron in forum Marketplace DiscussionReplies: 15Last Post: 23-08-2011, 08:58 PM -
Chinese 1.5kw Spindles
By jcb121 in forum Generic Chinese SpindlesReplies: 12Last Post: 28-07-2011, 06:20 PM
