Thread: Help wanted design laser X-axis
You might want to take a look at openservo.com it is an opensource project that upgrades the electronics in bog standard servos to get much better performance.
It is interesting that £20-£30 worth of electronics will get you a 12bit resolution mag non contact mag sensor, a cortex brain and a high power mosfet...
Hardware_Feature_Requests - OpenServo Wiki
08-03-2013 #2
I also think block and rail, belt and servo is the way to go, with the possibility of moving to a stepper to reduce costs.
On my current setup I am using a hiwin HGR15 Rail. I have learned from this setup that a smaller rail with a much lower overall height would be better than the HG15. The lower the height of the rail the smaller the pulley you need to make a loop of belt around the rail, connecting the belt ends at the front ethier side of the carriage.
Hiwin MG Linear Guideway is available in sizes (Rail Width) 5, 7, 9, 12, 15 (mm) and the height of the rails start at 3.6mm and go up to 10mm. In comparison the RG rail 15mm pitch has a height of 16.5mm so even at the 15mm pitch size the MG rail is significatly lower in profile.
I also found that only the lowest preload option gave a free moving carriage.
Another main issue I had was securing the pulley to the shaft of the motor. I have tried grub screws but the high acceleration rates and sudden change of direction when rastering work them loose in no time at all. A few possible solutions would be using an anerobic glue like locite bearing fit or a roll pin through the pulley and shaft. I like the look of these keyless bushing for small pulleys from CMT though, but they look expensive.
CNC routing and prototyping services www.cncscotland.co.uk
ADD ME ON FACEBOOKS
08-03-2013 #3
That clamping system looks brilliant. G.
08-03-2013 #4
You could try Fenner Drives trantorque keyless bushes or Lenze ETP Mini locking bushes. I have used both types and both are very good.
08-03-2013 #5
Thanks Web Goblin both look like good options, what was the smallest diameter of shaft you have used these on?
Searching for mini linear rails I can across this video. check out the 3mm rail in the bottom right corner.
ADD ME ON FACEBOOKS
The Following User Says Thank You to gavztheouch For This Useful Post:
08-03-2013 #6
I think the smallest I used was on a 10mm shaft. What I really liked about them apart from ease of fitting is that they are easily adjustable along the shaft to line up a pair of pulleys.
09-03-2013 #7
I have to be honest it all seems a rather expensive solution to move something that is relatively light?w why not go for something like the IGUS linear type rails and slides? very rigid and light and designed for this type of application?
WANTED: 3 axis cnc wanted bridgeport size
By franky in forum Items WantedReplies: 1Last Post: 31-05-2014, 08:57 AM -
Ross77's Z Axis Design
By Jonathan in forum Open Source Designs & PlansReplies: 1Last Post: 20-05-2013, 06:09 PM -
Z-Axis design and advice
By Mad Professor in forum Gantry/Router Machines & BuildingReplies: 22Last Post: 06-04-2013, 11:00 AM -
Need 6' x 4' bed, 4 axis router design.. Help..!
By fasteddy in forum Gantry/Router Machines & BuildingReplies: 29Last Post: 17-09-2010, 12:56 PM -
Y axis design
By GeorgeD in forum Gantry/Router Machines & BuildingReplies: 9Last Post: 15-07-2010, 03:04 AM
