Thread: Help wanted design laser X-axis
09-03-2013 #11
Have a look at this
igus® CNC-controlled laser cutting machineIf the nagging gets really bad......Get a bigger shed:naughty:
11-03-2013 #12
Igus is also a good choice, I have seen a few different laser cutters so far using Igus successfully. Comparing price and spec in terms of max speed and accerelation would be a route forward.
CNC routing and prototyping services www.cncscotland.co.uk
ADD ME ON FACEBOOKS
11-03-2013 #13
The way i see it if i had laser beams bouncing of mirrors that are moving, i would want not only rigidity but as smooth running as possible. Linear bearings may be great but there is still a lot of movement especially in small component form. In my opinion plastic or bronze bushe bearings would be my choice. I have used home made acetol bearings for my 3d printer build and work very well. Igus bearings would be better than because it allows for thermal expansion. With no real cutting forces going on you can get away with quite a lot...Drill some wood and give it a go, you will see what i mean.
WANTED: 3 axis cnc wanted bridgeport size
By franky in forum Items WantedReplies: 1Last Post: 31-05-2014, 08:57 AM -
Ross77's Z Axis Design
By Jonathan in forum Open Source Designs & PlansReplies: 1Last Post: 20-05-2013, 06:09 PM -
Z-Axis design and advice
By Mad Professor in forum Gantry/Router Machines & BuildingReplies: 22Last Post: 06-04-2013, 11:00 AM -
Need 6' x 4' bed, 4 axis router design.. Help..!
By fasteddy in forum Gantry/Router Machines & BuildingReplies: 29Last Post: 17-09-2010, 12:56 PM -
Y axis design
By GeorgeD in forum Gantry/Router Machines & BuildingReplies: 9Last Post: 15-07-2010, 03:04 AM
