    Im looking for a supplier of knurled nuts / thumbwheels in black like the one i have in the image or a very close variation to it,its about 15mm wide with a m5 tap through it,i need hundreds of them if any knows of a place,thanks.
Name:	15mm thumbwheel m5 006.jpg
ID:	8354Click image for larger version.
Name:	15mm thumbwheel m5 007.jpg
    The chances are you probably wont find an item like this off the shelf. I produce parts like this in volume on a regular basis on automatic lathes, which are most suited this style of work compared to cnc running up big motors and high running costs.
    I would advise you stay away from chemical blacking if its feasible. Most of it this days is a bit hit and miss quality wise, and will rust, sometimes prematurely sometimes in several years, but it will rust sooner or later. If you could live with bright zinc plating I would go down that route if the job would allow. Barrel plating is a cost effective way to plate in bulk and much more rust resistant.
    You can see examples of automatic style of work on my site In the automatics page. http://wardeng.co.uk
    Kind regards,
    Scott
  1. Aluminium Extrusion Supplier
    By adamh in forum Marketplace Discussion
    Last Post: 06-12-2013, 07:52 PM
  2. 1.5mm ball end mill supplier in the uk
    By luke11cnc in forum Marketplace Discussion
    Last Post: 21-01-2012, 08:25 PM
  3. UK Tooling Supplier
    By audioandy in forum General Discussion
    Last Post: 13-07-2010, 03:25 PM
  4. UK Supplier of Cutting tools
    By Ccrewz in forum Tool & Tooling Technology
    Last Post: 03-02-2010, 11:32 AM
  5. WANTED: UNC grub screw supplier?
    By m_c in forum Items Wanted
    Last Post: 01-11-2008, 01:51 AM
