Thread: Cutting lead flashing?
06-03-2013 #5
Thanks guys.
I'll try cutting with a regular straight flute bit for starters. That should avoid lifting the lead but I have a feeling its gonna clog and break the bit but it might not do. It cuts quite cleanly on the mitre saw so there's some hope.
If that fails a bit of creativity with an engraving bit might be worthwhile. Worse that can happen is it breaks the bit.
DC. You can score with a sharp blade and then break the pieces out with some back and forth bending along the score. Metal shears work too but regularly heavy duty scissors aren't up to it.
Delrin Lead nuts.
By Kammo1 in forum Gantry/Router Machines & BuildingReplies: 14Last Post: 27-01-2016, 08:36 PM -
Imperial sized lead screws?
By fentiger in forum Lead Screws, Nuts & SupportsReplies: 1Last Post: 14-06-2013, 10:16 PM -
one lead screw or two
By johngoodrich in forum Gantry/Router Machines & BuildingReplies: 10Last Post: 13-08-2011, 02:39 PM -
threaded rod/lead screws
By deannos in forum Gantry/Router Machines & BuildingReplies: 1Last Post: 23-05-2011, 09:40 AM -
How to choose a lead scew
By GTJim in forum Lead Screws, Nuts & SupportsReplies: 2Last Post: 15-02-2009, 12:30 PM
