Thread: motor mount nema 23
Here is the code for Linuxcnc (setup in mm), also the CamBam file if you wish to edit it and make changes. Just change the extension if you are using mach3 as it should work fine in that. It uses a 5mm carbide cutter for the whole routine. Warning spiral drilling of the screw holes will bing if not using flood coolant. I would cut the code to only go down a couple of mm to give you marks and drill those manually or change to suite. Code will cut two mounts with subtle differences as they were specific to me. Essentially the 1mm location hole for my machine but you should be able to remove that if not needed. I have to admit you are really on your own with this code and i'm sure many will say the same.
EnjoyIf the nagging gets really bad......Get a bigger shed:naughty:
The Following User Says Thank You to Swarfing For This Useful Post:
FOR SALE: Nema 23 4Nm Stepper Motor
By Shinobiwan in forum Items For SaleReplies: 16Last Post: 07-02-2013, 02:15 PM -
RFQ: Nema 23 motor mounts
By luke11cnc in forum Projects, Jobs & RequestsReplies: 14Last Post: 06-10-2011, 02:21 PM -
FOR SALE: Nema 23 motor mount (MBA-12C)
By D-man in forum Items For SaleReplies: 3Last Post: 09-12-2010, 11:39 PM -
WANTED: Nema 23 motor mount
By D-man in forum Items WantedReplies: 0Last Post: 29-06-2010, 07:36 AM -
WANTED: Wanted: Nema 23 motor mount
By D-man in forum Items WantedReplies: 0Last Post: 26-06-2010, 09:56 PM
