    Or place a 6mm mdf sheet on top and cut through it.
    A single flute cutter will also let you run at higher RPM for the same feedrate.
    Oil the cutter I just meant squirt some WD40 on it every minute or so. Even better you could try getting one of those plant watering spray bottles where you pump the top to pressurize it. Fill it with water and 10% water soluble cutting oil (white water oil, coolant fluid etc..).
    9000rpm at 550mm/min twin flute with WD40 is now producing acceptable results. I think my spindle speed was too fast and travel speed was too slow. The lub is probably helping as well.
    Thanks for the help.
  1. eBay: 8x4 sheet of 25mm thick aluminium plate.
    By T0rnado69 in forum Items On eBay UK
    Last Post: 18-04-2014, 02:01 AM
  2. WANTED: 100mmx100mm 6mm aluminium plate/sheet.
    By Isaac in forum Items Wanted
    Last Post: 06-02-2014, 12:11 AM
  3. 10 / 15mm thick 6061 aluminium alloy sheet ?
    By rnr107 in forum Marketplace Discussion
    Last Post: 14-01-2014, 12:15 AM
  4. FOR SALE: Aluminium Tooling Sheet - Various sizes
    By Fewco in forum Items For Sale
    Last Post: 16-01-2013, 04:27 PM
  5. Need to cut .5 Aluminium Sheet - Set-up Needed
    By Andrew in forum Metal Finishing Techniques
    Last Post: 15-08-2010, 04:12 PM
